Ir para o conteúdo principal
Garmin Vivoactive Side Button Replacement
O que você precisa
  1. Garmin Vivoactive Side Button Replacement, Wristband: passo 1, imagem 1 %32
    • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
    • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
    • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
  2. Garmin Vivoactive Side Button Replacement: passo 2, imagem 1 %32 Garmin Vivoactive Side Button Replacement: passo 2, imagem 2 %32
    • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
    • Gently push the strap's pin out. It will begin to protrude from the other end.
    • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
  3. Garmin Vivoactive Side Button Replacement, Display Unit: passo 3, imagem 1 %32
    • Place a heated iOpener over the display to loosen the adhesive.
    • After about a minute, the iOpener may be removed.
    • For more in depth instructions on using the iOpener, refer to the iOpener guide.
  4. Garmin Vivoactive Side Button Replacement: passo 4, imagem 1 %32 Garmin Vivoactive Side Button Replacement: passo 4, imagem 2 %32
    • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
  5. Garmin Vivoactive Side Button Replacement: passo 5, imagem 1 %32
    • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
    • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
    • Insert it a minimal distance to avoid damaging internal components.
  6. Garmin Vivoactive Side Button Replacement: passo 6, imagem 1 %32
    • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
    • Do the same on the opposite side of the device until you have a good grip of the screen.
  7. Garmin Vivoactive Side Button Replacement: passo 7, imagem 1 %32
    • Obtain a careful grip of the screen from two of its sides.
    • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
  8. Garmin Vivoactive Side Button Replacement: passo 8, imagem 1 %32
    • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
    • Upon completing this step, the screen should be free from the rest of the device.
    Thank you. The repair worked out very well. The tools made it possible. I had cracked the screen and now it is back to being a touch screen.
    Luigi Vitalini - Responder
  9. Garmin Vivoactive Side Button Replacement, Battery: passo 9, imagem 1 %32 Garmin Vivoactive Side Button Replacement, Battery: passo 9, imagem 2 %32
    • Follow previous guides until you've exposed the battery as shown.
    • Begin by removing the battery connector tab.
    • Be sure not to use a metal implement or your fingers to remove this tab. Doing so may cause personal harm or damage to the electrical components.
  10. Garmin Vivoactive Side Button Replacement: passo 10, imagem 1 %32 Garmin Vivoactive Side Button Replacement: passo 10, imagem 2 %32
    • Use a plastic opening pick to gently pry out the battery as shown.
    • The battery is Lithium Polymer, follow safe handling procedures and DO NOT deform it upon removal.
  11. Garmin Vivoactive Side Button Replacement: passo 11, imagem 1 %32 Garmin Vivoactive Side Button Replacement: passo 11, imagem 2 %32 Garmin Vivoactive Side Button Replacement: passo 11, imagem 3 %32
    • With the battery loose from the case, rotate it to expose the attached tab
    • Gently pry up the attached tab with a fingernail.
    • Keep the vibrator, circled in red, as you may need to solder it to the new battery upon re-installation later.
    After reaching step 11, you have to assemble the watch by reversing the steps. But how do you reverse step 3?
    How do you glue the watch face on again? What glue do I need to buy?
    alan
    Alan Rickayzen - Responder
    hello alan i would like to change the display is scratch can yuo guide me were can i find it...thank you
    Max Camargo - Responder
  12. Garmin Vivoactive Side Button Replacement, Motherboard: passo 12, imagem 1 %32 Garmin Vivoactive Side Button Replacement, Motherboard: passo 12, imagem 2 %32
    • Remove the four 2.4 mm screws with a PH00 Phillips head screwdriver.
    • Make an effort not to damage any nearby components of the motherboard with the screwdriver.
  13. Garmin Vivoactive Side Button Replacement: passo 13, imagem 1 %32 Garmin Vivoactive Side Button Replacement: passo 13, imagem 2 %32
    • Use the spudger to pry up the board from the case.
    • Insert the spudger a minimum distance beneath the board as there are components below.
    • Wiggle the exposed side of the board from each end until it comes free.
    • Use proper electrostatic discharge safety when removing and handling the board.
  14. Garmin Vivoactive Side Button Replacement: passo 14, imagem 1 %32 Garmin Vivoactive Side Button Replacement: passo 14, imagem 2 %32
    • Remove the GPS antenna by sliding it away from the board.
    • Keep track of the antenna and add it to the new board upon replacement.
  15. Garmin Vivoactive Side Button Replacement, Side Button: passo 15, imagem 1 %32 Garmin Vivoactive Side Button Replacement, Side Button: passo 15, imagem 2 %32 Garmin Vivoactive Side Button Replacement, Side Button: passo 15, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Orient the crescent shaped retaining clip so the open section faces the bottom of the device.
    • Remove the retaining clip by pulling up away from the device with the precision tweezers.
    • Be careful, the tweezers are quite sharp!
  16. Garmin Vivoactive Side Button Replacement: passo 16, imagem 1 %32 Garmin Vivoactive Side Button Replacement: passo 16, imagem 2 %32
    • After the retaining clip is removed, the spring and button will pop out.
    • With these very small components free from your device, take care not to lose them.
    • The spring is slightly compressed, so the button may pop out once the clip is removed.
Conclusão
Tessa Gunnin
Membro desde: 10/01/15
466 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 1-21, Maness Fall 2015 Membro de Cal Poly, Team 1-21, Maness Fall 2015
CPSU-MANESS-F15S1G21
4 Membros
Autoria de 17 guias
1Comentário do guia
But where can I get a replacement button?????
Steven Bentley - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 25
Ao todo: 5,568
