Ir para o conteúdo principal
Garmin StreetPilot c330 Battery Replacement
O que você precisa
  1. Garmin StreetPilot c330 Battery Replacement, Outer Casing: passo 1, imagem 1 %32 Garmin StreetPilot c330 Battery Replacement, Outer Casing: passo 1, imagem 2 %32 Garmin StreetPilot c330 Battery Replacement, Outer Casing: passo 1, imagem 3 %32
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Battery Replacement: passo 2, imagem 1 %32 Garmin StreetPilot c330 Battery Replacement: passo 2, imagem 2 %32 Garmin StreetPilot c330 Battery Replacement: passo 2, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Battery Replacement: passo 3, imagem 1 %32 Garmin StreetPilot c330 Battery Replacement: passo 3, imagem 2 %32
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Battery Replacement: passo 4, imagem 1 %32 Garmin StreetPilot c330 Battery Replacement: passo 4, imagem 2 %32 Garmin StreetPilot c330 Battery Replacement: passo 4, imagem 3 %32
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Battery Replacement: passo 5, imagem 1 %32
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Battery Replacement, Battery: passo 6, imagem 1 %32 Garmin StreetPilot c330 Battery Replacement, Battery: passo 6, imagem 2 %32 Garmin StreetPilot c330 Battery Replacement, Battery: passo 6, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the two screws from the battery bracket.
  7. Garmin StreetPilot c330 Battery Replacement: passo 7, imagem 1 %32 Garmin StreetPilot c330 Battery Replacement: passo 7, imagem 2 %32 Garmin StreetPilot c330 Battery Replacement: passo 7, imagem 3 %32
    • Carefully peel the metal bracket away from the battery.
    • Pull the battery away from the back cover.
    • Desolder the wires from the speakers using a soldering iron.
Conclusão
Uma outra pessoa concluiu este guia.
Adrian Leon
Membro desde: 10/07/10
173 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 22-1, Maness Fall 2010 Membro de Cal Poly, Team 22-1, Maness Fall 2010
CPSU-MANESS-F10S22G1
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 4,573
