Ir para o conteúdo principal
Garmin StreetPilot c320 Battery Replacement
O que você precisa
  1. Garmin StreetPilot c320 Battery Replacement, Rear Case Assembly: passo 1, imagem 1 %32 Garmin StreetPilot c320 Battery Replacement, Rear Case Assembly: passo 1, imagem 2 %32
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
    Pergunte ao FixBot
    Comentar
  2. Garmin StreetPilot c320 Battery Replacement: passo 2, imagem 1 %32 Garmin StreetPilot c320 Battery Replacement: passo 2, imagem 2 %32
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
    Pergunte ao FixBot
    Comentar
  3. Garmin StreetPilot c320 Battery Replacement: passo 3, imagem 1 %32
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
    Pergunte ao FixBot
    Comentar
  4. Garmin StreetPilot c320 Battery Replacement, Battery: passo 4, imagem 1 %32
    • Do not disconnect the black wire. Doing so may cause severe damage to your device.
    • Remove the two #00 Phillips screws securing the battery to the rear case assembly.
    Pergunte ao FixBot
    Comentar
  5. Garmin StreetPilot c320 Battery Replacement: passo 5, imagem 1 %32 Garmin StreetPilot c320 Battery Replacement: passo 5, imagem 2 %32
    • Use a plastic opening tool to peel back the battery bracket.
    • Cautiously grasp the battery and lift it out of the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 11-19, Maness Winter 2012 Membro de Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 Membros
Autoria de 4 guias
2Comentários do guia
Where can I purchase a new Garmin StreetPilot c320 Battery Replacement battery?
john Lyons
11 Cavanaugh Cres
Terrace Bay Ontario
P0T2W0 Canada
John Lyons - Responder Compartilhar
Thanks' - I just found two of my old Garmin StreetPilot c320 units in storage.
This will be the project of the evening watching movies.
New 18650 Battery with charging protection is ready.
Thankfully these are ten times easier than the TomTom just completed with new battery install.
Cheers
Philscbx - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 26
Ao todo: 2,874
