Ir para o conteúdo principal
Garmin Rino 700 Screen Replacement
O que você precisa
  1. Garmin Rino 700 Screen Replacement, Battery Disconnect: passo 1, imagem 1 %32
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
    Pergunte ao FixBot
    Comentar
  2. Garmin Rino 700 Screen Replacement: passo 2, imagem 1 %32 Garmin Rino 700 Screen Replacement: passo 2, imagem 2 %32
    • Remove the battery cover and set it to the side.
    Pergunte ao FixBot
    Comentar
  3. Garmin Rino 700 Screen Replacement: passo 3, imagem 1 %32 Garmin Rino 700 Screen Replacement: passo 3, imagem 2 %32
    • Use the spudger to disconnect the battery wire port from the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Garmin Rino 700 Screen Replacement, Motherboard: passo 4, imagem 1 %32 Garmin Rino 700 Screen Replacement, Motherboard: passo 4, imagem 2 %32
    • Using the T5 Torx screwdriver, remove the two 6.4 mm screws on the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Garmin Rino 700 Screen Replacement: passo 5, imagem 1 %32 Garmin Rino 700 Screen Replacement: passo 5, imagem 2 %32 Garmin Rino 700 Screen Replacement: passo 5, imagem 3 %32
    • Using the nylon spudger, lift the motherboard out of its position.
    • Slide the motherboard out of the front panel of the device.
    • Carefully disconnect the motherboard from the panel and remove it out of the device.
    Pergunte ao FixBot
    Comentar
  6. Garmin Rino 700 Screen Replacement, Screen: passo 6, imagem 1 %32 Garmin Rino 700 Screen Replacement, Screen: passo 6, imagem 2 %32 Garmin Rino 700 Screen Replacement, Screen: passo 6, imagem 3 %32
    • Carefully detach the screen at the bottom connections using your hands to reveal the ribbon connection.
    • For a guide on disconnecting and reconnecting the Zero Insertion Force (ZIF) connectors, please visit this guide.
    Pergunte ao FixBot
    Comentar
Conclusão
Abigail Dugan
Membro desde: 09/28/21
512 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 5-5, Hunter Fall 2021 Membro de Clemson, Team 5-5, Hunter Fall 2021
CLEM-HUNTER-F21S5G5
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 674
