Ir para o conteúdo principal
Garmin Nuvi 42LM Screen Replacement
O que você precisa
  1. Garmin Nuvi 42LM Screen Replacement, Back Cover: passo 1, imagem 1 %32 Garmin Nuvi 42LM Screen Replacement, Back Cover: passo 1, imagem 2 %32 Garmin Nuvi 42LM Screen Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Garmin Nuvi 42LM Screen Replacement: passo 2, imagem 1 %32 Garmin Nuvi 42LM Screen Replacement: passo 2, imagem 2 %32 Garmin Nuvi 42LM Screen Replacement: passo 2, imagem 3 %32
    • Pry the GPS open using a plastic opening tool.
    • When prying open the device, use caution to avoid damaging the motherboard.
    Pergunte ao FixBot
    Comentar
  3. Garmin Nuvi 42LM Screen Replacement, Motherboard: passo 3, imagem 1 %32 Garmin Nuvi 42LM Screen Replacement, Motherboard: passo 3, imagem 2 %32 Garmin Nuvi 42LM Screen Replacement, Motherboard: passo 3, imagem 3 %32
    • Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
    • There are two screws - one in the back and one in the front.
    Pergunte ao FixBot
    Comentar
  4. Garmin Nuvi 42LM Screen Replacement: passo 4, imagem 1 %32
    • Move the motherboard from from its designated location on the GPS.
    • Do not pull on red, green, and black cables when repositioning the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Garmin Nuvi 42LM Screen Replacement: passo 5, imagem 1 %32 Garmin Nuvi 42LM Screen Replacement: passo 5, imagem 2 %32
    • Gently unplug the red, green, and black bundled cable to remove the battery.
    Pergunte ao FixBot
    Comentar
  6. Garmin Nuvi 42LM Screen Replacement: passo 6, imagem 1 %32 Garmin Nuvi 42LM Screen Replacement: passo 6, imagem 2 %32
    • Use blue plastic opening tool to carefully pry the battery from the GPS.
    • You might need to use additional force when prying because there is adhesive glue on the back of the battery.
    Pergunte ao FixBot
    Comentar
  7. Garmin Nuvi 42LM Screen Replacement: passo 7, imagem 1 %32
    • Using a soldering iron, desolder the black and blue wires connected to the motherboard.
    • Once the black and blue wires are desoldered, llift the motherboard out and away from the device.
    • Check out this awesome guide on how to solder and desolder connections.
    Pergunte ao FixBot
    Comentar
  8. Garmin Nuvi 42LM Screen Replacement, Screen: passo 8, imagem 1 %32 Garmin Nuvi 42LM Screen Replacement, Screen: passo 8, imagem 2 %32
    • Push out the screen by pulling back the black clips.
    • The screen is attached to the motherboard and needs to be replaced with it.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
Where do I purchase the screen for the Nuvi 42LM?
DR ROGER BROWNE - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 712
