Ir para o conteúdo principal
Garmin DriveSmart 50 LMT Screen Replacement
O que você precisa
  1. Garmin DriveSmart 50 LMT Screen Replacement, Screen: passo 1, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the four screws from the bottom case.
    Pergunte ao FixBot
    Comentar
  2. Garmin DriveSmart 50 LMT Screen Replacement: passo 2, imagem 1 %32 Garmin DriveSmart 50 LMT Screen Replacement: passo 2, imagem 2 %32 Garmin DriveSmart 50 LMT Screen Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool or metal spudger to separate the back cover from the front frame. Start from the corners and work your way around the device.
    • Carefully lift the back cover off to reveal the motherboard and ribbon cables.
    Pergunte ao FixBot
    Comentar
  3. Garmin DriveSmart 50 LMT Screen Replacement: passo 3, imagem 1 %32
    • Use a spudger to unlock the screen cable ZIF connector.
    • Use angled sweezers to slide the cable from the socket.
    • You may need to flip the display assembly over for easier access to the display connector.
    Pergunte ao FixBot
    Comentar
  4. Garmin DriveSmart 50 LMT Screen Replacement: passo 4, imagem 1 %32 Garmin DriveSmart 50 LMT Screen Replacement: passo 4, imagem 2 %32
    • If the screen does not lift easily, use an iOpener to soften the adhesive.
    • Use a nylon spudger to pry the old display assembly.
    • The screen is held in place with adhesive, so be careful when removing it to avoid bending the frame.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Lydia Barrett
Membro desde: 09/25/25
463 Reputação
Autoria de 3 guias
Equipe
Texas Tech, Team 41-5, Allen Fall 2025 Membro de Texas Tech, Team 41-5, Allen Fall 2025
TTU-ALLEN-F25S41G5
3 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 20
Ao todo: 107
