Introdução
This guide will illustrate how to install a new headphone jack on an original Game Boy system. You'll need to know how to solder for this replacement, so be sure to check out iFixit's soldering technique guide.
O que você precisa
The headphone jack is located on the bottom of the rear outer casing, near the battery compartment.
Use a Phillips #00 screwdriver to remove the two screws holding the headphone jack in place.
16 outras pessoas executaram este guia.
