Ir para o conteúdo principal
Fusion5 5.5 Gen II Top Speaker Replacement
O que você precisa
  1. Fusion5 5.5 Gen II Top Speaker Replacement, Back Cover: passo 1, imagem 1 %32 Fusion5 5.5 Gen II Top Speaker Replacement, Back Cover: passo 1, imagem 2 %32
    • Hold the device with the screen facing away from you and the back of the device facing you.
    • Locate the groove at the bottom corner of the device.
    • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
  2. Fusion5 5.5 Gen II Top Speaker Replacement, Midframe: passo 2, imagem 1 %32 Fusion5 5.5 Gen II Top Speaker Replacement, Midframe: passo 2, imagem 2 %32
    • Remove thirteen 3mm Phillips #00 screws from the midframe.
    • Remove the single 5mm Phillips #0 screw below the camera.
  3. Fusion5 5.5 Gen II Top Speaker Replacement: passo 3, imagem 1 %32 Fusion5 5.5 Gen II Top Speaker Replacement: passo 3, imagem 2 %32
    • Using an opening pick, begin prying one of the top corners to remove the midframe from the device.
    • Be careful not to damage the cables inside the device when you pry the midframe off.
  4. Fusion5 5.5 Gen II Top Speaker Replacement, Motherboard: passo 4, imagem 1 %32
    • Using tweezers, flip the brown tab securing the ribbon cable.
    • Make sure to only lift the flap and not the connector socket due to its susceptibility to break off.
    • Grab the ribbon cable with the tweezers and pull it from its socket on the motherboard.
  5. Fusion5 5.5 Gen II Top Speaker Replacement: passo 5, imagem 1 %32
    • Remove the two 3mm Phillips #00 screws from the motherboard.
  6. Fusion5 5.5 Gen II Top Speaker Replacement: passo 6, imagem 1 %32
    • Grab the motherboard from the right edges.
    • Flip the motherboard to the left side of the device.
    • Be careful not to tear the cables attached to the motherboard as you flip the motherboard.
    • Desolder the red and blue wires to remove the motherboard from the device.
  7. Fusion5 5.5 Gen II Top Speaker Replacement, Top Speaker: passo 7, imagem 1 %32 Fusion5 5.5 Gen II Top Speaker Replacement, Top Speaker: passo 7, imagem 2 %32
    • Using tweezers, grasp the speaker at the top of the phone and gently pull it out of the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 274
