Ir para o conteúdo principal
Fujifilm X30 Motherboard Replacement
O que você precisa
  1. Fujifilm X30 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Fujifilm X30 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Turn the camera upside down.
    • Place your thumb on the switch, and slide it towards the center of the camera.
    • The compartment will pop open.
  2. Fujifilm X30 Motherboard Replacement: passo 2, imagem 1 %32
    • Once you have the battery compartment open, slide the orange tab away from the battery until it ejects.
  3. Fujifilm X30 Motherboard Replacement: passo 3, imagem 1 %32
    • Pull the battery out.
  4. Fujifilm X30 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Fujifilm X30 Motherboard Replacement, Motherboard: passo 4, imagem 2 %32 Fujifilm X30 Motherboard Replacement, Motherboard: passo 4, imagem 3 %32
    • Begin by removing the outside screws using a Phillips #000 Screwdriver:
    • Remove the three 3.6 mm silver screws located on the bottom of the camera.
    • Remove all four of the 4.7 mm screws from the sides of the camera.
  5. Fujifilm X30 Motherboard Replacement: passo 5, imagem 1 %32 Fujifilm X30 Motherboard Replacement: passo 5, imagem 2 %32
    • Remove all screws below using a Phillips #000 Screwdriver:
    • Lift up the screen and remove the two 4.5 mm screws located in the bottom corners.
    • Remove the 4.0 mm screw that is located behind the screen and directly under the eye piece.
  6. Fujifilm X30 Motherboard Replacement: passo 6, imagem 1 %32
    • Carefully lift up the bottom piece of the camera to remove it.
  7. Fujifilm X30 Motherboard Replacement: passo 7, imagem 1 %32
    • Do not pull hard when removing the backing because it could rip the orange strip attached to the motherboard.
    • Gently pull off the back of the camera from the left side so that it is partially open.
    • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it
    • Refer to the next step to see pictures of how to properly use the spudger when removing a strip.
  8. Fujifilm X30 Motherboard Replacement: passo 8, imagem 1 %32 Fujifilm X30 Motherboard Replacement: passo 8, imagem 2 %32 Fujifilm X30 Motherboard Replacement: passo 8, imagem 3 %32
    • For all five indicated orange strips:
    • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it.
  9. Fujifilm X30 Motherboard Replacement: passo 9, imagem 1 %32
    • For the last orange strip located behind the top strip:
  10. Fujifilm X30 Motherboard Replacement: passo 10, imagem 1 %32
    • This step is required if you are doing a full disassembly, but can be skipped if you are only removing the motherboard.
    • For the two orange strips attached to the capacitor circuitboard:
  11. Fujifilm X30 Motherboard Replacement: passo 11, imagem 1 %32 Fujifilm X30 Motherboard Replacement: passo 11, imagem 2 %32 Fujifilm X30 Motherboard Replacement: passo 11, imagem 3 %32
    • Remove all screws listed below using a Phillips #000 screwdriver:
    • Remove the two 3.4 mm screws at the bottom of the silver plate.
    • Hold back the clear strip to reveal a 2.8 mm screw on the left of the silver plate and remove it.
    • Peel back the copper plate.
  12. Fujifilm X30 Motherboard Replacement: passo 12, imagem 1 %32
    • Remove the three 2.6 mm screws located in the top two corners and the bottom right corner of the motherboard using a Phillips #000 screwdriver.
  13. Fujifilm X30 Motherboard Replacement: passo 13, imagem 1 %32 Fujifilm X30 Motherboard Replacement: passo 13, imagem 2 %32
    • Tilt up the motherboard to locate the black, grey, and red wires.
    • Desolder these wires in order to completely remove the motherboard.
    • You can learn about soldering techniques here.
Conclusão
Tori Baker
Membro desde: 01/11/16
262 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 70-3, Forte Winter 2016 Membro de Cal Poly, Team 70-3, Forte Winter 2016
CPSU-FORTE-W16S70G3
5 Membros
Autoria de 4 guias
2 comentários
On step 11 becareful not to detach flex surface from aluminium plate. You could end up braking CCD contacts as I did.
arnau COSTA BEAL - Responder
Hello, can anybody tell me where i can find the Fuji X30 Motherboard as a spare part? Mine is broken and i don’t want to throw away the camera…. but I don’t find any shop. Thanks for help! Cheers
Dan - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 40
Ao todo: 3,405
