Ir para o conteúdo principal
Front Panel Assembly Replacement
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. Front Panel Assembly Replacement, Front Panel Assembly: passo 1, imagem 1 %32
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
    Pergunte ao FixBot
    Comentar
  2. Front Panel Assembly Replacement: passo 2, imagem 1 %32
    • Remove the button cover by lifting the cover away from the tablet.
    Pergunte ao FixBot
    Comentar
  3. Front Panel Assembly Replacement: passo 3, imagem 1 %32
    • Using the Torx screwdriver, remove the 4mm screws.
    Pergunte ao FixBot
    Comentar
  4. Front Panel Assembly Replacement: passo 4, imagem 1 %32
    • With the Torx screwdriver, remove the two 5mm screws.
    Pergunte ao FixBot
    Comentar
  5. Front Panel Assembly Replacement: passo 5, imagem 1 %32 Front Panel Assembly Replacement: passo 5, imagem 2 %32
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
    Pergunte ao FixBot
    Comentar
  6. Front Panel Assembly Replacement: passo 6, imagem 1 %32
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
    Pergunte ao FixBot
    Comentar
  7. Front Panel Assembly Replacement: passo 7, imagem 1 %32 Front Panel Assembly Replacement: passo 7, imagem 2 %32
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Carlos Salas
Membro desde: 09/30/16
194 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 4-6, Passmore Fall 2016 Membro de USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 265
