Ir para o conteúdo principal
Framework Laptop 12 Fastener Guide
O que você precisa
    1. Framework Laptop 12 Fastener Guide, Fasteners information: passo 1, imagem 1 %32 Framework Laptop 12 Fastener Guide, Fasteners information: passo 1, imagem 2 %32
      • The Fastener Kit contains the following:
      • Grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head"
      • Silver screws labeled "M1.6 2.5mm fastener with a 3.5mm diameter 0.5mm thick T5 head"
      • Black screws labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head"
      • Gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head"
      • Silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head"
      • Silver screws labeled "M1.6 4.0mm fastener with a 4.6mm diameter 0.6mm thick T5 head"
      • Your Framework Laptop comes with a spare screw of each size, attached to the chassis above the battery. You can use the Fastener Kit to replenish any screws you used there.
      Pergunte ao FixBot
      Comentar
    2. Framework Laptop 12 Fastener Guide, Antenna screws: passo 2, imagem 1 %32 Framework Laptop 12 Fastener Guide, Antenna screws: passo 2, imagem 2 %32 Framework Laptop 12 Fastener Guide, Antenna screws: passo 2, imagem 3 %32
      • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the antennas.
      Pergunte ao FixBot
      Comentar
    3. Framework Laptop 12 Fastener Guide, Display screws: passo 3, imagem 1 %32 Framework Laptop 12 Fastener Guide, Display screws: passo 3, imagem 2 %32
      • Use the silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head" to secure the display.
      • Tighten the screws until they're snug. Don't over-tighten them, or you may break the screw tabs.
      Pergunte ao FixBot
      Comentar
    4. Framework Laptop 12 Fastener Guide, Expansion Card lock screws: passo 4, imagem 1 %32 Framework Laptop 12 Fastener Guide, Expansion Card lock screws: passo 4, imagem 2 %32 Framework Laptop 12 Fastener Guide, Expansion Card lock screws: passo 4, imagem 3 %32
      • Use the black screws labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head" to secure the Expansion Card latches.
      • Use the silver screws labeled "M1.6 2.5mm fastener with a 3.5mm diameter 0.5mm thick T5 head" to replace the Expansion Card lock screws.
      Pergunte ao FixBot
      Comentar
    5. Framework Laptop 12 Fastener Guide, Hinge screws (bottom): passo 5, imagem 1 %32 Framework Laptop 12 Fastener Guide, Hinge screws (bottom): passo 5, imagem 2 %32 Framework Laptop 12 Fastener Guide, Hinge screws (bottom): passo 5, imagem 3 %32
      • Use the silver screws labeled "M2 4.0mm fastener with a 4.6mm diameter 0.6mm thick T5 head" to secure the hinges to the Bottom Cover.
      Pergunte ao FixBot
      Comentar
    6. Framework Laptop 12 Fastener Guide, Hinge screws (top): passo 6, imagem 1 %32 Framework Laptop 12 Fastener Guide, Hinge screws (top): passo 6, imagem 2 %32 Framework Laptop 12 Fastener Guide, Hinge screws (top): passo 6, imagem 3 %32
      • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the hinges to the Top Cover.
      Pergunte ao FixBot
      Comentar
    7. Framework Laptop 12 Fastener Guide, Power Button screw: passo 7, imagem 1 %32 Framework Laptop 12 Fastener Guide, Power Button screw: passo 7, imagem 2 %32
      • Use the grey screw labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head" to secure the Power Button.
      Pergunte ao FixBot
      Comentar
    8. Framework Laptop 12 Fastener Guide, SSD clip screw: passo 8, imagem 1 %32 Framework Laptop 12 Fastener Guide, SSD clip screw: passo 8, imagem 2 %32
      • Use the black screw labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head" to secure the SSD clip.
      Pergunte ao FixBot
      Comentar
    9. Framework Laptop 12 Fastener Guide, Touchpad screws: passo 9, imagem 1 %32 Framework Laptop 12 Fastener Guide, Touchpad screws: passo 9, imagem 2 %32 Framework Laptop 12 Fastener Guide, Touchpad screws: passo 9, imagem 3 %32
      • Use the grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head" to secure the touchpad.
      • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the touchpad pogo connector.
      Pergunte ao FixBot
      Comentar
    10. Framework Laptop 12 Fastener Guide, Webcam screws: passo 10, imagem 1 %32 Framework Laptop 12 Fastener Guide, Webcam screws: passo 10, imagem 2 %32
      • Use the silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head" to secure the webcam.
      Pergunte ao FixBot
      Comentar
Conclusão
If you need help, contact Framework support.
Arthur Shi
Membro desde: 01/03/18
344.621 Reputação
Autoria de 915 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 44
Ao todo: 295
