Ir para o conteúdo principal
Framework Laptop 12 Display Replacement
O que você precisa
    1. Framework Laptop 12 Display Replacement, Power down your laptop: passo 1, imagem 1 %32 Framework Laptop 12 Display Replacement, Power down your laptop: passo 1, imagem 2 %32 Framework Laptop 12 Display Replacement, Power down your laptop: passo 1, imagem 3 %32
      • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
      • The indicator LEDs along the edges should be unlit. The laptop should be silent.
      • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
      • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
      Pergunte ao FixBot
      Comentar
    1. Framework Laptop 12 Display Replacement, Open your laptop: passo 2, imagem 1 %32 Framework Laptop 12 Display Replacement, Open your laptop: passo 2, imagem 2 %32
      • Open the laptop lid so that both the screen and the base lie flat on your work surface.
      Pergunte ao FixBot
      Comentar
    2. Framework Laptop 12 Display Replacement, Remove the Display Cover: passo 3, imagem 1 %32 Framework Laptop 12 Display Replacement, Remove the Display Cover: passo 3, imagem 2 %32
      • The Display Cover is held in place with magnets along the top edge and clips along the remaining edges.
      • Use the flat end of your Framework Screwdriver to pry up the right edge of the Display Cover.
      Pergunte ao FixBot
      Comentar
    3. Framework Laptop 12 Display Replacement: passo 4, imagem 1 %32 Framework Laptop 12 Display Replacement: passo 4, imagem 2 %32 Framework Laptop 12 Display Replacement: passo 4, imagem 3 %32
      • Slide your fingers under the top edge of the Display Cover to release it from the laptop.
      Pergunte ao FixBot
      Comentar
    4. Framework Laptop 12 Display Replacement: passo 5, imagem 1 %32 Framework Laptop 12 Display Replacement: passo 5, imagem 2 %32
      • Remove the Display Cover.
      Pergunte ao FixBot
      Comentar
    1. Framework Laptop 12 Display Replacement, Remove the display screws: passo 6, imagem 1 %32 Framework Laptop 12 Display Replacement, Remove the display screws: passo 6, imagem 2 %32
      • Use your Framework Screwdriver to remove the four 3.3 mm‑long T5 Torx screws securing the display to the Top Cover.
      • These screws are not captive. Store them in a safe location for reassembly.
      Pergunte ao FixBot
      Comentar
    2. Framework Laptop 12 Display Replacement, Slide the display down: passo 7, imagem 1 %32 Framework Laptop 12 Display Replacement, Slide the display down: passo 7, imagem 2 %32 Framework Laptop 12 Display Replacement, Slide the display down: passo 7, imagem 3 %32
      • Insert the bit end of your Framework Screwdriver into the small hole on the display, below the Framework logo.
      • Slide the display down towards the hinge edge to release the tabs holding the top edge of the display in place.
      Pergunte ao FixBot
      Comentar
    3. Framework Laptop 12 Display Replacement, Lift the display: passo 8, imagem 1 %32 Framework Laptop 12 Display Replacement, Lift the display: passo 8, imagem 2 %32
      • Use your fingers to lift the top edge of the display from the Top Cover.
      Pergunte ao FixBot
      Comentar
    4. Framework Laptop 12 Display Replacement, Swing the display over: passo 9, imagem 1 %32 Framework Laptop 12 Display Replacement, Swing the display over: passo 9, imagem 2 %32 Framework Laptop 12 Display Replacement, Swing the display over: passo 9, imagem 3 %32
      • Use your fingers to carefully swing the display over so it lies on top of the keyboard.
      Pergunte ao FixBot
      Comentar
    1. Framework Laptop 12 Display Replacement, Remove the webcam bracket: passo 10, imagem 1 %32
      • Use your Framework Screwdriver to remove the two 3.3 mm‑long T5 Torx screws securing the webcam bracket on the top edge behind the display.
      Pergunte ao FixBot
      Comentar
    2. Framework Laptop 12 Display Replacement: passo 11, imagem 1 %32 Framework Laptop 12 Display Replacement: passo 11, imagem 2 %32
      • Lift and remove the webcam bracket.
      Pergunte ao FixBot
      Comentar
    3. Framework Laptop 12 Display Replacement, Disconnect the webcam: passo 12, imagem 1 %32 Framework Laptop 12 Display Replacement, Disconnect the webcam: passo 12, imagem 2 %32 Framework Laptop 12 Display Replacement, Disconnect the webcam: passo 12, imagem 3 %32
      • Use the flat end of your Framework Screwdriver to lift the webcam out of its recess.
      • Avoid touching the black camera module near the center of the webcam.
      • Flip the webcam over and gently hold it down with your fingers.
      Pergunte ao FixBot
      Comentar
    4. Framework Laptop 12 Display Replacement: passo 13, imagem 1 %32 Framework Laptop 12 Display Replacement: passo 13, imagem 2 %32 Framework Laptop 12 Display Replacement: passo 13, imagem 3 %32
      • Use the flat end of your Framework Screwdriver or a fingernail to gently pry up the locking tab on the webcam cable ZIF connector.
      Pergunte ao FixBot
      Comentar
    5. Framework Laptop 12 Display Replacement, Remove the webcam: passo 14, imagem 1 %32 Framework Laptop 12 Display Replacement, Remove the webcam: passo 14, imagem 2 %32 Framework Laptop 12 Display Replacement, Remove the webcam: passo 14, imagem 3 %32
      • Slide the webcam cable out of its connector.
      • Remove the webcam.
      Pergunte ao FixBot
      Comentar
    1. Framework Laptop 12 Display Replacement, Detach the webcam cable: passo 15, imagem 1 %32 Framework Laptop 12 Display Replacement, Detach the webcam cable: passo 15, imagem 2 %32 Framework Laptop 12 Display Replacement, Detach the webcam cable: passo 15, imagem 3 %32
      • The webcam cable is lightly adhered to the display.
      • Grab the webcam cable with your fingers and slowly peel it away from the display.
      • Carefully move the cable off of the display.
      Pergunte ao FixBot
      Comentar
    2. Framework Laptop 12 Display Replacement, Disconnect the touch control cable: passo 16, imagem 1 %32 Framework Laptop 12 Display Replacement, Disconnect the touch control cable: passo 16, imagem 2 %32 Framework Laptop 12 Display Replacement, Disconnect the touch control cable: passo 16, imagem 3 %32
      • Use the flat end of your Framework Screwdriver or a fingernail to gently pry up the locking tab on the touch control ZIF connector near the hinge edge of the display.
      • Use your fingers to grab the touch control cable by the blue tab and slide the cable out of the connector.
      Pergunte ao FixBot
      Comentar
    3. Framework Laptop 12 Display Replacement, Separate the silver tape: passo 17, imagem 1 %32 Framework Laptop 12 Display Replacement, Separate the silver tape: passo 17, imagem 2 %32 Framework Laptop 12 Display Replacement, Separate the silver tape: passo 17, imagem 3 %32
      • Slide the flat end of your Framework Screwdriver under the grounding tape securing the display cable.
      • Lift slowly to separate the tape from the display.
      • Keep this tape clean and intact during your repair. You'll use it to attach the cable during reassembly.
      Pergunte ao FixBot
      Comentar
    4. Framework Laptop 12 Display Replacement, Detach the display cable: passo 18, imagem 1 %32 Framework Laptop 12 Display Replacement, Detach the display cable: passo 18, imagem 2 %32 Framework Laptop 12 Display Replacement, Detach the display cable: passo 18, imagem 3 %32
      • The display cable is lightly adhered to the bottom edge of the display.
      • Slide the flat end of your Framework Screwdriver under the length of the display cable to separate it from the display.
      Pergunte ao FixBot
      Comentar
    5. Framework Laptop 12 Display Replacement, Disconnect the display cable: passo 19, imagem 1 %32 Framework Laptop 12 Display Replacement, Disconnect the display cable: passo 19, imagem 2 %32
      • Use your fingers to peel up the clear tab covering the display cable connector.
      Pergunte ao FixBot
      Comentar
    6. Framework Laptop 12 Display Replacement: passo 20, imagem 1 %32 Framework Laptop 12 Display Replacement: passo 20, imagem 2 %32
      • Use the flat end of your Framework Screwdriver to flip up the locking bar around the display connector.
      Pergunte ao FixBot
      Comentar
    7. Framework Laptop 12 Display Replacement: passo 21, imagem 1 %32 Framework Laptop 12 Display Replacement: passo 21, imagem 2 %32
      • Make sure the locking bar doesn't fall back in place while you disconnect the display cable.
      • Grasp the display cable near the connector and slide it out of the connector.
      • If you have trouble getting the cable to slide out, gently wiggle it to loosen the connection.
      Pergunte ao FixBot
      Comentar
    8. Framework Laptop 12 Display Replacement, Remove the display: passo 22, imagem 1 %32 Framework Laptop 12 Display Replacement, Remove the display: passo 22, imagem 2 %32 Framework Laptop 12 Display Replacement, Remove the display: passo 22, imagem 3 %32
      • Carefully lift and remove the display.
      Pergunte ao FixBot
      Comentar
    1. Framework Laptop 12 Display Replacement, Disassembly complete: passo 23, imagem 1 %32
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Pergunte ao FixBot
      Comentar
    1. Framework Laptop 12 Display Replacement, Prepare the replacement display: passo 24, imagem 1 %32 Framework Laptop 12 Display Replacement, Prepare the replacement display: passo 24, imagem 2 %32
      • The Framework Display Kit comes with an extra webcam bracket. If you're not using this kit to repair your display, skip this step.
      • Inspect the replacement display and carefully peel off any protective liners.
      • Use your Framework Screwdriver to remove the two 3.3 mm‑long T5 Torx screws securing the webcam bracket on the replacement display.
      • Remove the webcam bracket.
      • Remove any protective liners that may be in the webcam recess. The liners are normally clear or colored plastic films that easily detach.
      • You can use the replacement bracket and screws, or you can reuse your existing ones.
      Pergunte ao FixBot
      Comentar
    2. Framework Laptop 12 Display Replacement, Install the display: passo 25, imagem 1 %32 Framework Laptop 12 Display Replacement, Install the display: passo 25, imagem 2 %32
      • Carefully lay the display screen-side down on top of the Input Cover. The edge with the webcam should lay near the touchpad edge.
      • The Input Cover magnets will align the display to itself.
      • Use your fingers to slide the display off the Input Cover magnets towards the hinge edge so that the display cable can reach its connector.
      Pergunte ao FixBot
      Comentar
    3. Framework Laptop 12 Display Replacement: passo 26, imagem 1 %32 Framework Laptop 12 Display Replacement: passo 26, imagem 2 %32
      • Use your fingers to grab the display cable by the clear tab and the locking bar.
      • Align the display cable with its connector and slide it in until it's fully seated.
      Pergunte ao FixBot
      Comentar
    4. Framework Laptop 12 Display Replacement: passo 27, imagem 1 %32 Framework Laptop 12 Display Replacement: passo 27, imagem 2 %32 Framework Laptop 12 Display Replacement: passo 27, imagem 3 %32
      • Swing the locking bar down over the connector.
      • If the locking bar can't swing all the way down around the connector, you'll need to insert the cable deeper into the connector.
      • Lay the clear tab over the connector and press it onto the display.
      Pergunte ao FixBot
      Comentar
    5. Framework Laptop 12 Display Replacement: passo 28, imagem 1 %32 Framework Laptop 12 Display Replacement: passo 28, imagem 2 %32
      • Slide the touch control cable into the ZIF connector up to the printed line on the cable.
      • Use your finger to flip down and gently press the locking tab in place.
      Pergunte ao FixBot
      Comentar
    6. Framework Laptop 12 Display Replacement: passo 29, imagem 1 %32 Framework Laptop 12 Display Replacement: passo 29, imagem 2 %32
      • Use your finger to press the display cable grounding tape onto the metal back of the display.
      • Use your fingers to press the display cable onto the display.
      Pergunte ao FixBot
      Comentar
    7. Framework Laptop 12 Display Replacement: passo 30, imagem 1 %32
      • Use your fingers to press the webcam cable onto the display.
      Pergunte ao FixBot
      Comentar
    1. Framework Laptop 12 Display Replacement, Install the webcam: passo 31, imagem 1 %32 Framework Laptop 12 Display Replacement, Install the webcam: passo 31, imagem 2 %32 Framework Laptop 12 Display Replacement, Install the webcam: passo 31, imagem 3 %32
      • Bend an inch (2.5 cm) of the webcam cable over so that the shiny side is facing you.
      • Slide the webcam cable into the ZIF connector up to the printed line on the cable.
      Pergunte ao FixBot
      Comentar
    2. Framework Laptop 12 Display Replacement: passo 32, imagem 1 %32 Framework Laptop 12 Display Replacement: passo 32, imagem 2 %32
      • Use your fingers to flip the webcam back into its recess in the Top Cover.
      Pergunte ao FixBot
      Comentar
    3. Framework Laptop 12 Display Replacement: passo 33, imagem 1 %32 Framework Laptop 12 Display Replacement: passo 33, imagem 2 %32 Framework Laptop 12 Display Replacement: passo 33, imagem 3 %32
      • Align the webcam bracket to the Top Cover and lay it in place.
      • Make sure the tabs on the top edge of the webcam bracket sit in their slots on the top edge of the display.
      Pergunte ao FixBot
      Comentar
    4. Framework Laptop 12 Display Replacement: passo 34, imagem 1 %32
      • Use your Framework Screwdriver to install the two 3.3 mm‑long T5 Torx screws to secure the webcam.
      Pergunte ao FixBot
      Comentar
    1. Framework Laptop 12 Display Replacement, Swing the display over: passo 35, imagem 1 %32 Framework Laptop 12 Display Replacement, Swing the display over: passo 35, imagem 2 %32 Framework Laptop 12 Display Replacement, Swing the display over: passo 35, imagem 3 %32
      • Use your fingers to carefully swing the display over so it lies on top of the Top Cover.
      Pergunte ao FixBot
      Comentar
    2. Framework Laptop 12 Display Replacement, Slide the display in place: passo 36, imagem 1 %32 Framework Laptop 12 Display Replacement, Slide the display in place: passo 36, imagem 2 %32 Framework Laptop 12 Display Replacement, Slide the display in place: passo 36, imagem 3 %32
      • Align the display in the Top Cover such that the top edge of the display is slightly below the top edge of the Top Cover.
      • Use your fingers to slide the display upwards to latch the tabs on the top edge of the display.
      • The top edge shouldn't have any gaps when the display's in place.
      Pergunte ao FixBot
      Comentar
    3. Framework Laptop 12 Display Replacement, Install the display screws: passo 37, imagem 1 %32 Framework Laptop 12 Display Replacement, Install the display screws: passo 37, imagem 2 %32
      • Use your Framework Screwdriver to install the four 3.3 mm‑long T5 Torx screws to secure the display to the Top Cover.
      • Tighten the screws until they're snug. Don't over-tighten them, or you may damage the screw tabs.
      Pergunte ao FixBot
      Comentar
    1. Framework Laptop 12 Display Replacement, Install the Display Cover: passo 38, imagem 1 %32 Framework Laptop 12 Display Replacement, Install the Display Cover: passo 38, imagem 2 %32
      • Align the Display Cover to the bottom of the display.
      Pergunte ao FixBot
      Comentar
    2. Framework Laptop 12 Display Replacement: passo 39, imagem 1 %32 Framework Laptop 12 Display Replacement: passo 39, imagem 2 %32
      • Use your finger to press along the length of the Display Cover to snap it onto the laptop.
      • Make sure all the clips along the left, top, and right edges are fully seated.
      Pergunte ao FixBot
      Comentar
Conclusão
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Arthur Shi
Membro desde: 01/03/18
344.609 Reputação
Autoria de 915 guias
Equipe
Guide Team Membro de Guide Team
Staff
10 Membros
Autoria de 31.372 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 27
Últimos 30 dias: 104
Ao todo: 1,581
