Ir para o conteúdo principal
Fixing Pop up Flash Receptacle
O que você precisa
    1. Fixing Pop up Flash Receptacle, Battery: passo 1, imagem 1 %32
      • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
      Pergunte ao FixBot
      Comentar
    2. Fixing Pop up Flash Receptacle: passo 2, imagem 1 %32
      • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
      Pergunte ao FixBot
      Comentar
    3. Fixing Pop up Flash Receptacle: passo 3, imagem 1 %32
      • Remove the battery from inside the battery housing and set the cover aside.
      Pergunte ao FixBot
      Comentar
    1. Fixing Pop up Flash Receptacle, Fixing Pop up Flash Receptacle: passo 4, imagem 1 %32 Fixing Pop up Flash Receptacle, Fixing Pop up Flash Receptacle: passo 4, imagem 2 %32
      • The inside of the flash shoe has a removable cover which is just snapped in place.
      • Using the flathead screwdriver, pry up on the front end of the cover.
      • Warning: The cover is on tight and is tough to pry off.
      Pergunte ao FixBot
      Comentar
    2. Fixing Pop up Flash Receptacle: passo 5, imagem 1 %32
      • Loosen, but do not remove, the 4 screws on top of the flash shoe.
      Pergunte ao FixBot
      Comentar
    3. Fixing Pop up Flash Receptacle: passo 6, imagem 1 %32
      • Locate the black pludger sticking up out of the flash shoe.
      • The black pludger may not be visible, which is why the flash is broken. Just locate the hole to where it should be and move on to the next step.
      Pergunte ao FixBot
      Comentar
    4. Fixing Pop up Flash Receptacle: passo 7, imagem 1 %32
      • If you can remove the bracket from the camera to reset the hotshoe, this is preferable to using a paperclip to reset the sensors.
      • Push a paperclip in and out of the plunger hole, ensuring the plunger moves up and down freely.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Mark
Membro desde: 04/20/11
197 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 8-9, Regan Spring 2011 Membro de Cal Poly, Team 8-9, Regan Spring 2011
CPSU-REGAN-S11S8G9
4 Membros
Autoria de 25 guias
2Comentários do guia
What about the other way, where the external flash IS installed (and the camera is successfully communicating TTL focal length data to it) yet the camera still doesn’t believe there is an external flash installed? Sometimes twisting the external flash a little causes the camera to change its mind and then it works, but then it usually forgets by the next exposure.
Think this mechanism could be causing that behavior too?
Andrew - Responder Compartilhar
Take the hotshoe off, and make sure they move freely. Once they're moving freely, reverse disassembly and make sure it works. This will ensure it is properly "reset".
Nick - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 61
Ao todo: 5,323
