Ir para o conteúdo principal
Fitbit Blaze Vibration Motor Replacement
O que você precisa
    1. Fitbit Blaze  Vibration Motor Replacement, Wristband: passo 1, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement, Wristband: passo 1, imagem 2 %32
      • Locate the front LCD screen on your device.
      • Fitbit logo should appear in the bottom center of the screen.
      Pergunte ao FixBot
      Comentar
    2. Fitbit Blaze  Vibration Motor Replacement: passo 2, imagem 1 %32
      • Push the screen out through the back of the metal ring enclosure.
      • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
      Pergunte ao FixBot
      Comentar
    3. Fitbit Blaze  Vibration Motor Replacement: passo 3, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement: passo 3, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement: passo 3, imagem 3 %32
      • Locate the metal pin behind the wristband located on the edge of metal ring.
      • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
      • Use a small amount of force to avoid damaging the pins.
      • Remove wristband.
      Pergunte ao FixBot
      Comentar
    1. Fitbit Blaze  Vibration Motor Replacement, Display Frame: passo 4, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement, Display Frame: passo 4, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement, Display Frame: passo 4, imagem 3 %32
      • Locate the pin behind the second wristband located on the edge of metal ring.
      • Insert the pointed end of the metal spudger into the pin hold and push it into opposite direction.
      • Remove wristband.
      Pergunte ao FixBot
      Comentar
    1. Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: passo 5, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: passo 5, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: passo 5, imagem 3 %32
      • Place device screen face down and locate the four screws attaching the back cover.
      • Use a T3 torx head or T3 torx screwdriver to remove the four screws.
      Pergunte ao FixBot
      Comentar
    2. Fitbit Blaze  Vibration Motor Replacement: passo 6, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement: passo 6, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement: passo 6, imagem 3 %32
      • Grab the back, lift and open like a book to expose the motherboard. Locate the ribbon connector on the left.
      • Use a plastic spudger tool on the ribbon connected from the heart rate monitor to the motherboard.
      • Insert and lift the plastic opening tool to release the ribbon.
      • Only a small force when lifting the plastic connector is needed to avoid damage.
      Pergunte ao FixBot
      Comentar
    3. Fitbit Blaze  Vibration Motor Replacement: passo 7, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement: passo 7, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement: passo 7, imagem 3 %32
      • Separate the back and set aside, locate the three screws attaching the motherboard.
      • Use a PH000 head or a PH000 screwdriver to remove the three screws.
      Pergunte ao FixBot
      Comentar
    4. Fitbit Blaze  Vibration Motor Replacement: passo 8, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement: passo 8, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement: passo 8, imagem 3 %32
      • Use a plastic spudger tool on the ribbons connected to the motherboard.
      • Insert the tool under the ribbon and lift to release the connection.
      Pergunte ao FixBot
      Comentar
    5. Fitbit Blaze  Vibration Motor Replacement: passo 9, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement: passo 9, imagem 2 %32 Fitbit Blaze  Vibration Motor Replacement: passo 9, imagem 3 %32
      • Lift and push the motherboard to the side to uncover the 167mAh battery.
      • Use a plastic spudger tool to pry out the battery from its adhesive plastic underneath.
      • Lift up and pull downward to remove battery. Switch to the top portion of the battery and push downward to pry out battery.
      Pergunte ao FixBot
      Comentar
    6. Fitbit Blaze  Vibration Motor Replacement: passo 10, imagem 1 %32 Fitbit Blaze  Vibration Motor Replacement: passo 10, imagem 2 %32
      • Flip the motherboard back to the front to locate the metal pins from the vibration motor soldered to the board.
      • Desolder the connection to remove the motor component.
      • Follow this guide on how to solder and desolder connectors Soldering Guide
      • Excessive heat will damage the components, so do not apply the soldering iron to the component for long amounts of time.
      Pergunte ao FixBot
      Comentar
Conclusão
Adrian Borrego
Membro desde: 02/20/17
2.242 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S3-G3, Sullivan Spring 2017 Membro de USF Tampa, Team S3-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G3
4 Membros
Autoria de 20 guias
4Comentários do guia
anyone got a part number or a description of the motor that gets replaced. looking to do this and fix. thanks
Ben - Responder Compartilhar
And how many destroyed “FitBit Blaze” are we going to see now?
tjhbob - Responder Compartilhar
what kind of motor can you replace this with?
dbick - Responder Compartilhar
Any idea what is the value of the C3 capacitor?
P J - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 15
Últimos 30 dias: 42
Ao todo: 3,672
