Ir para o conteúdo principal
Fairphone 3 Rear Camera Module Replacement
O que você precisa
    1. Fairphone 3 Rear Camera Module Replacement, Back Cover: passo 1, imagem 1 %32 Fairphone 3 Rear Camera Module Replacement, Back Cover: passo 1, imagem 2 %32
      • Power off your phone before beginning disassembly.
      • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
      • Pry the back cover up to start separating its plastic clips.
      Pergunte ao FixBot
      Comentar
    2. Fairphone 3 Rear Camera Module Replacement: passo 2, imagem 1 %32 Fairphone 3 Rear Camera Module Replacement: passo 2, imagem 2 %32 Fairphone 3 Rear Camera Module Replacement: passo 2, imagem 3 %32
      • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
      • Lift the back cover to release the rest of the plastic clips and remove it.
      • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
      Pergunte ao FixBot
      Comentar
    1. Fairphone 3 Rear Camera Module Replacement, Battery: passo 3, imagem 1 %32 Fairphone 3 Rear Camera Module Replacement, Battery: passo 3, imagem 2 %32
      • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
      • Lever the battery up until you can get a good grip.
      Pergunte ao FixBot
      Comentar
    2. Fairphone 3 Rear Camera Module Replacement: passo 4, imagem 1 %32 Fairphone 3 Rear Camera Module Replacement: passo 4, imagem 2 %32
      • Lift the battery out of its recess and remove it.
      Pergunte ao FixBot
      Comentar
    1. Fairphone 3 Rear Camera Module Replacement, Display Assembly: passo 5, imagem 1 %32
      • Whenever a Phillips #00 screw is mentioned you can also unfasten it with a size #0 bit/screwdriver.
      • Remove the thirteen Phillips #00 screws (4 mm length).
      Pergunte ao FixBot
      Comentar
    2. Fairphone 3 Rear Camera Module Replacement: passo 6, imagem 1 %32 Fairphone 3 Rear Camera Module Replacement: passo 6, imagem 2 %32 Fairphone 3 Rear Camera Module Replacement: passo 6, imagem 3 %32
      • Make sure to insert the opening pick between the midframe and the display module and not into the small gap next to the screen. Otherwise you're going to pry up the screen instead of the whole display module.
      • Insert an opening pick between the midframe and the display module on the right edge of the phone.
      • Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
      Pergunte ao FixBot
      Comentar
    3. Fairphone 3 Rear Camera Module Replacement: passo 7, imagem 1 %32 Fairphone 3 Rear Camera Module Replacement: passo 7, imagem 2 %32
      • Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
      Pergunte ao FixBot
      Comentar
    4. Fairphone 3 Rear Camera Module Replacement: passo 8, imagem 1 %32 Fairphone 3 Rear Camera Module Replacement: passo 8, imagem 2 %32
      • Slide the opening pick along the left side to pry the display module up.
      • The display module should pop out of the midframe during this process. In case it doesn’t, check for remaining clamps you might have missed.
      Pergunte ao FixBot
      Comentar
    5. Fairphone 3 Rear Camera Module Replacement: passo 9, imagem 1 %32 Fairphone 3 Rear Camera Module Replacement: passo 9, imagem 2 %32
      • Remove the display assembly.
      • To reinstall the display-module press it into place on all sides until you can hear a snap from the plastic clamps to make sure it sits flush with the frame.
      • If you install a new display: The new display module comes with a white plastic cover held by 2 screws over the processor and the connectors. This needs to be taken off.
      Pergunte ao FixBot
      Comentar
    1. Fairphone 3 Rear Camera Module Replacement, Rear Camera Module: passo 10, imagem 1 %32
      • Remove the two 4.1mm-long Phillips #00 screws.
      Pergunte ao FixBot
      Comentar
    2. Fairphone 3 Rear Camera Module Replacement: passo 11, imagem 1 %32 Fairphone 3 Rear Camera Module Replacement: passo 11, imagem 2 %32
      • Use a spudger to pry up and disconnect the camera connecting cable.
      Pergunte ao FixBot
      Comentar
    3. Fairphone 3 Rear Camera Module Replacement: passo 12, imagem 1 %32 Fairphone 3 Rear Camera Module Replacement: passo 12, imagem 2 %32
      • Use a spudger to pry up the rear camera module.
      Pergunte ao FixBot
      Comentar
    4. Fairphone 3 Rear Camera Module Replacement: passo 13, imagem 1 %32
      • Remove the rear camera module.
      Pergunte ao FixBot
      Comentar
Conclusão
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
18 outras pessoas executaram este guia.
Adriana Zwink
Membro desde: 12/18/19
68.927 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 72.312 guias
3Comentários do guia
How NOT to remove the display!
I just destroyed my display module a bit and had to fix it with glue. :(
This works better: https://www.youtube.com/watch?v=wGTYZNzg...
caroline - Responder Compartilhar
I think this guide should mention that the camera connecting cable can become disconnected accidentally on its other end (under the metallic cover) which is easy to miss. This forum post helped me: https://forum.fairphone.com/t/be-careful...
The metallic cover can be removed easily after screwing off two Torx screws. Couple of people on the forum experienced this and it helped me solve my problem.
cmur2 - Responder Compartilhar
Pas de problème pour changer le module. Les explications données par ifixit sont claires et aisées à suivre.
Eric Beaucarne - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 82
Ao todo: 9,995
