Ir para o conteúdo principal
Fahrenheit FHT 125PRMR Heating Plate Replacement
O que você precisa
  1. Fahrenheit FHT 125PRMR Heating Plate Replacement, Heating Plate: passo 1, imagem 1 %32
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Heating Plate Replacement: passo 2, imagem 1 %32
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Heating Plate Replacement: passo 3, imagem 1 %32 Fahrenheit FHT 125PRMR Heating Plate Replacement: passo 3, imagem 2 %32
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Heating Plate Replacement: passo 4, imagem 1 %32
    • Using Philips head (PH1) remove the 6 mm black screw that was underneath the spring as well as the 6 mm black screw next to the heating plate. Remove the panel the screws were holding down.
  5. Fahrenheit FHT 125PRMR Heating Plate Replacement: passo 5, imagem 1 %32
    • Using Philips head (PH1) remove the two 4 mm silver screws on the sides of dial panel cover
  6. Fahrenheit FHT 125PRMR Heating Plate Replacement: passo 6, imagem 1 %32 Fahrenheit FHT 125PRMR Heating Plate Replacement: passo 6, imagem 2 %32
    • Using Philips head (PH00) to remove the 4 mm silver screw on the dial. Remove the dial with your hand.
  7. Fahrenheit FHT 125PRMR Heating Plate Replacement: passo 7, imagem 1 %32
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Heating Plate Replacement: passo 8, imagem 1 %32
  9. Fahrenheit FHT 125PRMR Heating Plate Replacement: passo 9, imagem 1 %32 Fahrenheit FHT 125PRMR Heating Plate Replacement: passo 9, imagem 2 %32
    • Remove 3 sliver screws (3mm) (PH1) from the motherboard.
  10. Fahrenheit FHT 125PRMR Heating Plate Replacement: passo 10, imagem 1 %32
Conclusão
Omar El Mounayri
Membro desde: 09/29/16
61 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-2, Harley Fall 2016 Membro de IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Duração total: 2,147
