Ir para o conteúdo principal
Ethernet Cable RJ45 Connector Replacement
O que você precisa
    1. Ethernet Cable RJ45 Connector Replacement, Identify the parts of the tool: passo 1, imagem 1 %32 Ethernet Cable RJ45 Connector Replacement, Identify the parts of the tool: passo 1, imagem 2 %32
      • First let's identify which side of the tool performs which functions.
      • One side of the tool is used for stripping wires. You can tell because it has two blades, one on each side, as indicated in the first photo.
      • The other side is used for cutting wires. You can tell because one side is bladed while the other is flat, as seen in the second photo.
      • If you are using a slightly different tool, the use of it will still be very similar to how it is shown in this guide.
      Pergunte ao FixBot
      Comentar
    2. Ethernet Cable RJ45 Connector Replacement, Cut the wire: passo 2, imagem 1 %32 Ethernet Cable RJ45 Connector Replacement, Cut the wire: passo 2, imagem 2 %32
      • Place the wire across the blade of the wire cutter.
      • Squeeze the handles of the tool together until the wire is cut.
      Pergunte ao FixBot
      Comentar
    3. Ethernet Cable RJ45 Connector Replacement, Strip off the cover: passo 3, imagem 1 %32 Ethernet Cable RJ45 Connector Replacement, Strip off the cover: passo 3, imagem 2 %32 Ethernet Cable RJ45 Connector Replacement, Strip off the cover: passo 3, imagem 3 %32
      • Place about a quarter of an inch of the cable into the stripping end of the tool.
      • Squeeze the handles of the tools together until the tool clicks and then release.
      • Pull the stripped wire cover from the cable with your fingers.
      • If your wire cutter does not have a side specifically for stripping wires, you can simply use the wire cutting part but not squeeze the handles all the way down, so that it only cuts the outer casing of the cable.
      • When you have successfully completed this step, the cable should appear similar to the third photo of this step.
      • If you have shielded cable above Cat.5e you might want to follow this guide for stripping.
      Pergunte ao FixBot
      Comentar
    4. Ethernet Cable RJ45 Connector Replacement, Organize the wires: passo 4, imagem 1 %32 Ethernet Cable RJ45 Connector Replacement, Organize the wires: passo 4, imagem 2 %32
      • Arrange these cables in the order shown in the diagram.
      • Use your fingers to squeeze the cables about to keep them in order.
      • This is how the cables will be inserted into the connector.
      • If you have S/FTP cables you likely won't have half white/coloured wires. These wires will instead be pure white and you will have to go by the colour of its partner in the twisted pair.
      Pergunte ao FixBot
      Comentar
    5. Ethernet Cable RJ45 Connector Replacement, Trim the wires: passo 5, imagem 1 %32 Ethernet Cable RJ45 Connector Replacement, Trim the wires: passo 5, imagem 2 %32
      • Insert the cables into wire cutters.
      • Cut all the cables at the end so they are flush together.
      • Keep squeezing on the cables even after the cut to ensure they maintain the correct order.
      Pergunte ao FixBot
      Comentar
    6. Ethernet Cable RJ45 Connector Replacement, Insert the new RJ45 connector: passo 6, imagem 1 %32 Ethernet Cable RJ45 Connector Replacement, Insert the new RJ45 connector: passo 6, imagem 2 %32
      • Hold the wires closely together in the order shown in the previous step and push them into the new RJ45 connector, with the clip end of the connector facing down, and the orange/white wire to the left.
      • Push the wires to the end of the connector ensuring that all wires enter their respective chambers in the connector.
      • If you inspect the top of the connector you should be able to see the tips of the wires pushed against the end of the connector, as shown in the second photo in this step.
      Pergunte ao FixBot
      Comentar
    7. Ethernet Cable RJ45 Connector Replacement, Crimp the connector: passo 7, imagem 1 %32
      • Place the RJ45 into the crimper at the end of the tool. Push it in all the way, it will fit exactly in the tool—you can not push it in too far.
      • Squeeze the handles of the tool together until it clicks and releases.
      Pergunte ao FixBot
      Comentar
Conclusão
You have now replaced the RJ45 connector, you may test the fix by using using a cable tester. If it does not work, you can always follow the steps in this guide to try again.
35 outras pessoas executaram este guia.
Equipe
1Comentário do guia
Merci beaucoup
Yaya Tamate - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 28
Últimos 7 dias: 212
Últimos 30 dias: 1,269
Ao todo: 118,127
