Ir para o conteúdo principal
How to test an Ethernet Cable
O que você precisa
    1. How to test an Ethernet Cable, Ports: passo 1, imagem 1 %32 How to test an Ethernet Cable, Ports: passo 1, imagem 2 %32
      • The tester has two ports on each part:
      • RJ11 (6P2C)
      • RJ45 (8P8C)
      Pergunte ao FixBot
      Comentar
    2. How to test an Ethernet Cable, Connect the cable: passo 2, imagem 1 %32
      • Connect one end of the cable on one half of the tester each.
      • If you are testing jacks you can just connect them with a known good patch cable.
      • If the other side of your cable is already connected to a switch or some other device you can connect the MASTER device only.
      • Only do this with cable testers you trust, since crappy cable testers might not limit the current they send through the data lines.
      Pergunte ao FixBot
      Comentar
    3. How to test an Ethernet Cable, Switch on the tester: passo 3, imagem 1 %32
      • Switch on the tester.
      • The tester has two modes: ON and S. There is no difference in the two modes besides the testing interval on S being more drawn out.
      Pergunte ao FixBot
      Comentar
    4. How to test an Ethernet Cable, Test the cable: passo 4, imagem 1 %32
      • The tester will go through all the wires in sequence. If the sequence of the green lights blinking does not line up you might have swapped some wires when wiring the connector.
      • If some lights do not light up there might be a break in the cable or you made a mistake when crimping the connector.
      • For Fast Ethernet (100 Mbit/s) you only need pins 1, 2, 3 and 6. Some cheap cables may not even have more than these four wires.
      • G means ground. For most consumer applications up to 1GbE it should be fine if your ground is not properly connected.
      Pergunte ao FixBot
      Comentar
Conclusão
Good luck on your next project!
Uma outra pessoa concluiu este guia.
Sebastian
Membro desde: 08/19/18
33.392 Reputação
Autoria de 72 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 93
Últimos 30 dias: 381
Ao todo: 22,205
