Ir para o conteúdo principal
Equity Alarm Clock 13014 Alarm Switch Replacement
O que você precisa
  1. Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: passo 1, imagem 1 %32 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: passo 1, imagem 2 %32 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: passo 1, imagem 3 %32
    • Remove the battery door using your finger nail or an opening tool.
    Pergunte ao FixBot
    Comentar
  2. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: passo 2, imagem 1 %32 Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the 3 screws on the back cover.
    Pergunte ao FixBot
    Comentar
  3. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove Cover: passo 3, imagem 1 %32
    • Remove the back cover gently.
    • DO NOT pull the back cover off quickly or you may damage the wires connected.
    Pergunte ao FixBot
    Comentar
  4. Equity Alarm Clock 13014 Alarm Switch Replacement: passo 4, imagem 1 %32 Equity Alarm Clock 13014 Alarm Switch Replacement: passo 4, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the small screw located above the alarm switch.
    • Remove the small screw located below the alarm switch as well.
    Pergunte ao FixBot
    Comentar
  5. Equity Alarm Clock 13014 Alarm Switch Replacement: passo 5, imagem 1 %32 Equity Alarm Clock 13014 Alarm Switch Replacement: passo 5, imagem 2 %32
    • Place the end of the soldering iron on the end of the wire connected to the copper cylinder to detach the wire.
    • If you are unfamiliar with soldering, take a look at this article: How to Solder and Desolder Connections.
    • To replace the alarm switch, attach one end of new alarm switch wire to the copper cylinder.
    • Use a Phillips #1 screwdriver to reinstall the switch screws.
    • Follow steps in reverse order to assemble the clock.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 45
Ao todo: 1,905
