Ir para o conteúdo principal
Epson Powerlite 460 Lens Replacement
O que você precisa
  1. Epson Powerlite 460 Lens Replacement, Motherboard: passo 1, imagem 1 %32 Epson Powerlite 460 Lens Replacement, Motherboard: passo 1, imagem 2 %32
    • Orient the device so that the projection window is facing down and the bottom of the device is visible.
    • Remove the eleven 13.3mm screws using a Phillips #2 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Epson Powerlite 460 Lens Replacement: passo 2, imagem 1 %32 Epson Powerlite 460 Lens Replacement: passo 2, imagem 2 %32 Epson Powerlite 460 Lens Replacement: passo 2, imagem 3 %32
    • Flip the device over so that the projection window is facing up.
    • Slide the air filter cover opener in the direction indicated by the arrow to release the air filter cover.
    • Remove the air filter cover.
    Pergunte ao FixBot
    Comentar
  3. Epson Powerlite 460 Lens Replacement: passo 3, imagem 1 %32 Epson Powerlite 460 Lens Replacement: passo 3, imagem 2 %32
    • Remove the two 13.3mm screws from the top cover above the air filter using a Phillips #2 screwdriver.
    • Remove one 13.3mm screw from above the connection panel using a Phillips #2 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Epson Powerlite 460 Lens Replacement: passo 4, imagem 1 %32 Epson Powerlite 460 Lens Replacement: passo 4, imagem 2 %32
    • Remove the cover from the projector and set aside.
    • The cover will be connected by ribbon cables. You do not need to disconnect these to complete this repair, but it may make it easier.
    Pergunte ao FixBot
    Comentar
  5. Epson Powerlite 460 Lens Replacement: passo 5, imagem 1 %32 Epson Powerlite 460 Lens Replacement: passo 5, imagem 2 %32 Epson Powerlite 460 Lens Replacement: passo 5, imagem 3 %32
    • Use the opening tool to disconnect eleven clip cables on the motherboard.
    • These will be the colorful cables connected with white plastic clips.
    • Disconnect the black cable clip by pressing the side tabs. Use the opening tool to release the cable if it is difficult.
    • To disconnect the ribbon cables, use the opening tool to lift the locking flap on the connector and slide the cable back and out of the connector.
    Pergunte ao FixBot
    Comentar
  6. Epson Powerlite 460 Lens Replacement: passo 6, imagem 1 %32
    • Disconnect the clip cable from below the motherboard and behind the connection panel.
    Pergunte ao FixBot
    Comentar
  7. Epson Powerlite 460 Lens Replacement: passo 7, imagem 1 %32 Epson Powerlite 460 Lens Replacement: passo 7, imagem 2 %32 Epson Powerlite 460 Lens Replacement: passo 7, imagem 3 %32
    • Remove seven 8.1mm screws from the motherboard using a Phillips #2 screwdriver.
    • Remove the 8.1mm screw from the back of the projection panel below the motherboard using a Phillips #2 screwdriver.
    • Remove two 8.1mm screws from the front of the projection panel using a Phillips #2 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. Epson Powerlite 460 Lens Replacement: passo 8, imagem 1 %32
    • Gently lift the motherboard out of the device.
    Pergunte ao FixBot
    Comentar
  9. Epson Powerlite 460 Lens Replacement, Lens: passo 9, imagem 1 %32 Epson Powerlite 460 Lens Replacement, Lens: passo 9, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the two 9.1mm screws from the focus lever adjuster.
    • Remove the focus lever mechanism by sliding the metal rod out of the plastic lever and lifting out of the unit.
    Pergunte ao FixBot
    Comentar
  10. Epson Powerlite 460 Lens Replacement: passo 10, imagem 1 %32 Epson Powerlite 460 Lens Replacement: passo 10, imagem 2 %32
    • Remove the two 13.3mm screws from the metal bracket surrounding the lens unit using a Phillips #0 screwdriver.
    • Remove the bracket.
    Pergunte ao FixBot
    Comentar
  11. Epson Powerlite 460 Lens Replacement: passo 11, imagem 1 %32 Epson Powerlite 460 Lens Replacement: passo 11, imagem 2 %32
    • Remove the two 13.3mm screws from the lens cover using a Phillips #0 screwdriver.
    • Use your finger to release the clips on either side of the lens cover.
    • Lift the lens cover to remove it from the projector.
    Pergunte ao FixBot
    Comentar
  12. Epson Powerlite 460 Lens Replacement: passo 12, imagem 1 %32 Epson Powerlite 460 Lens Replacement: passo 12, imagem 2 %32
    • Remove the five 9.4mm screws from the lens using a Phillips #0 screwdriver.
    • Lift the lens out of the unit.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Ao todo: 426
