Ir para o conteúdo principal
Epson Powerlite 410W Lens Replacement
O que você precisa
  1. Epson Powerlite 410W Lens Replacement, Top Cover: passo 1, imagem 1 %32
    • Press the power button located on top of the projector.
    • Remember to let the projector cool off completely after turning off the power before beginning the repair.
    Pergunte ao FixBot
    Comentar
  2. Epson Powerlite 410W Lens Replacement: passo 2, imagem 1 %32
    • Remove eight screws from the bottom of the device using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Epson Powerlite 410W Lens Replacement: passo 3, imagem 1 %32 Epson Powerlite 410W Lens Replacement: passo 3, imagem 2 %32 Epson Powerlite 410W Lens Replacement: passo 3, imagem 3 %32
    • Turn the projector so the power button is on top.
    • Gently pull up the cover until it pops off.
    • Do not pull too far; a ribbon cable still connects the top cover to the motherboard.
    • Disconnect the ribbon cable that attaches the cover to the motherboard.
    • Remove the cover and place to the side.
    Pergunte ao FixBot
    Comentar
  4. Epson Powerlite 410W Lens Replacement, Motherboard: passo 4, imagem 1 %32 Epson Powerlite 410W Lens Replacement, Motherboard: passo 4, imagem 2 %32
    • Remove the two screws holding down the motherboard using a Phillips #00 screwdriver.
    • Remove the four screws holding down the I/O board using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Epson Powerlite 410W Lens Replacement: passo 5, imagem 1 %32
    • Remove the seven cables that are running to the motherboard by pulling them out of their sockets.
    Pergunte ao FixBot
    Comentar
  6. Epson Powerlite 410W Lens Replacement: passo 6, imagem 1 %32 Epson Powerlite 410W Lens Replacement: passo 6, imagem 2 %32 Epson Powerlite 410W Lens Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using a plastic opening tool, gently pry up the black tabs holding in the ribbon cables on the motherboard.
    • Using tweezers, gently pull the ribbon cables out of the sockets.
    Pergunte ao FixBot
    Comentar
  7. Epson Powerlite 410W Lens Replacement: passo 7, imagem 1 %32
    • Gently pull the motherboard up and tilt it back, revealing the last cable attached to the motherboard. Disconnect this cable.
    • Remove the motherboard from the projector.
    Pergunte ao FixBot
    Comentar
  8. Epson Powerlite 410W Lens Replacement, Lens: passo 8, imagem 1 %32 Epson Powerlite 410W Lens Replacement, Lens: passo 8, imagem 2 %32
    • Remove four 2.5 mm silver hex screws from the silver bracket.
    • Depending on your screwdriver size, a flexible bit extension may be required.
    Pergunte ao FixBot
    Comentar
  9. Epson Powerlite 410W Lens Replacement: passo 9, imagem 1 %32 Epson Powerlite 410W Lens Replacement: passo 9, imagem 2 %32
    • Remove the four silver screws from the base of the lens.
    Pergunte ao FixBot
    Comentar
  10. Epson Powerlite 410W Lens Replacement: passo 10, imagem 1 %32 Epson Powerlite 410W Lens Replacement: passo 10, imagem 2 %32
    • Pull the lens assembly out from the silver bracket.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Ao todo: 510
