Ir para o conteúdo principal
Epson PowerLite 83+ Projector Lens Replacement
O que você precisa
  1. Epson PowerLite 83+ Projector Lens Replacement, Motherboard: passo 1, imagem 1 %32 Epson PowerLite 83+ Projector Lens Replacement, Motherboard: passo 1, imagem 2 %32 Epson PowerLite 83+ Projector Lens Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
    • A long shank Phillips #2 screwdriver is required to reach the screws.
    Pergunte ao FixBot
    Comentar
  2. Epson PowerLite 83+ Projector Lens Replacement: passo 2, imagem 1 %32 Epson PowerLite 83+ Projector Lens Replacement: passo 2, imagem 2 %32 Epson PowerLite 83+ Projector Lens Replacement: passo 2, imagem 3 %32
    • Flip the projector over and lift the top cover from the rear of the projector.
    • Two cables are connected at the front that prevent full removal.
    • Disconnect the slide cover JST connector. Grip the connector and rock it back and forth while apply gentle pressure.
    Pergunte ao FixBot
    Comentar
  3. Epson PowerLite 83+ Projector Lens Replacement: passo 3, imagem 1 %32 Epson PowerLite 83+ Projector Lens Replacement: passo 3, imagem 2 %32
    • Using a spudger, lift the ribbon cable's locking tab along the length of the cable.
    • Remove the ribbon cable from the connector and place the projector's top cover aside.
    Pergunte ao FixBot
    Comentar
  4. Epson PowerLite 83+ Projector Lens Replacement: passo 4, imagem 1 %32 Epson PowerLite 83+ Projector Lens Replacement: passo 4, imagem 2 %32 Epson PowerLite 83+ Projector Lens Replacement: passo 4, imagem 3 %32
    • Remove the two 6 mm Phillips #2 screws.
    • Remove the single silver 5 mm Phillips #2 screw.
    Pergunte ao FixBot
    Comentar
  5. Epson PowerLite 83+ Projector Lens Replacement: passo 5, imagem 1 %32 Epson PowerLite 83+ Projector Lens Replacement: passo 5, imagem 2 %32 Epson PowerLite 83+ Projector Lens Replacement: passo 5, imagem 3 %32
    • Using your fingernails or a spudger, remove the eleven JST connectors attached to the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Epson PowerLite 83+ Projector Lens Replacement: passo 6, imagem 1 %32 Epson PowerLite 83+ Projector Lens Replacement: passo 6, imagem 2 %32
    • Using a spudger, flip up the plastic locking tabs and gently remove the three ribbon cables from their connectors.
    Pergunte ao FixBot
    Comentar
  7. Epson PowerLite 83+ Projector Lens Replacement: passo 7, imagem 1 %32 Epson PowerLite 83+ Projector Lens Replacement: passo 7, imagem 2 %32
    • Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
    • Lift the motherboard from the front side of the projector to clear the ribbon cables.
    • Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
    • Remove the motherboard from the case.
    Pergunte ao FixBot
    Comentar
  8. Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: passo 8, imagem 1 %32 Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: passo 8, imagem 2 %32 Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: passo 8, imagem 3 %32
    • Remove the four 6 mm Phillips #2 screws securing the fan bracket.
    • Remove the fan bracket by pulling straight up and set it aside.
    Pergunte ao FixBot
    Comentar
  9. Epson PowerLite 83+ Projector Lens Replacement: passo 9, imagem 1 %32 Epson PowerLite 83+ Projector Lens Replacement: passo 9, imagem 2 %32 Epson PowerLite 83+ Projector Lens Replacement: passo 9, imagem 3 %32
    • Remove the four 6 mm Phillips #2 screws securing the projector lens.
    Pergunte ao FixBot
    Comentar
  10. Epson PowerLite 83+ Projector Lens Replacement: passo 10, imagem 1 %32 Epson PowerLite 83+ Projector Lens Replacement: passo 10, imagem 2 %32
    • Unhook the JST connector wire from wire stay and move it aside.
    • Remove the projector lens from the base.
    Pergunte ao FixBot
    Comentar
Conclusão
Billy Fox
Membro desde: 02/22/22
467 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 2-4, Hunter Spring 2022 Membro de Clemson, Team 2-4, Hunter Spring 2022
CLEM-HUNTER-S22S2G4
4 Membros
Autoria de 6 guias
1Comentário do guia
source for a replacement lens? I surely need one.
christopher wanko - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 34
Ao todo: 902
