Ir para o conteúdo principal
Envizen V100M Motherboard Replacement
O que você precisa
  1. Envizen V100M Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Envizen V100M Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver.
    • The two screws for the back cover are: 1.5mm diameter x 3.5mm long
    Pergunte ao FixBot
    Comentar
  2. Envizen V100M Motherboard Replacement: passo 2, imagem 1 %32 Envizen V100M Motherboard Replacement: passo 2, imagem 2 %32 Envizen V100M Motherboard Replacement: passo 2, imagem 3 %32
    • Pry along the edge of the device to separate the back cover from the device.
    • The speakers are attached to the back cover and motherboard assembly so remove carefully.
    Pergunte ao FixBot
    Comentar
  3. Envizen V100M Motherboard Replacement, Battery: passo 3, imagem 1 %32 Envizen V100M Motherboard Replacement, Battery: passo 3, imagem 2 %32 Envizen V100M Motherboard Replacement, Battery: passo 3, imagem 3 %32
    • Remove the non-conductive tape located on the battery and motherboard assembly.
    Pergunte ao FixBot
    Comentar
  4. Envizen V100M Motherboard Replacement: passo 4, imagem 1 %32 Envizen V100M Motherboard Replacement: passo 4, imagem 2 %32 Envizen V100M Motherboard Replacement: passo 4, imagem 3 %32
    • Slide the ifixit spudger under the battery, and work down the side of the battery, releasing it from the adhesive holding it down.
    • Remove battery from the Envizen V100M.
    Pergunte ao FixBot
    Comentar
  5. Envizen V100M Motherboard Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the solder from the red and black wires from the battery attached to the motherboard. Here is a guide on how to solder.
    • Remove the red and black wire from the motherboard using tweezers. If tweezers are unable to remove the wires, heat can be used to loosen the solder allowing for the wires to be removed.
    Pergunte ao FixBot
    Comentar
  6. Envizen V100M Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the black and white wires from the motherboard. These wires power the LCD screen. Remove the black and white wires by first trying tweezers and if difficult use heat to loosen the solder allowing for the removal of the wires.
    • Note during final installation remember to match the location of the black and white wires to the picture
    Pergunte ao FixBot
    Comentar
  7. Envizen V100M Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 Envizen V100M Motherboard Replacement, Motherboard: passo 7, imagem 2 %32
    • Remove the five screws holding the motherboard assembly down using the ifixit PH00 screwdriver
    • These screws are also 1.5mm in diameter and 3.5mm long
    Pergunte ao FixBot
    Comentar
  8. Envizen V100M Motherboard Replacement: passo 8, imagem 1 %32 Envizen V100M Motherboard Replacement: passo 8, imagem 2 %32
    • Remove the three ribbon cables from their couplings.
    • Using the prying tool gently push the bracket up, allowing for the cable to right out.
    Pergunte ao FixBot
    Comentar
  9. Envizen V100M Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the solder holding the white ribbon cable in place, here is a guide on how to solder.
    • Then flip the motherboard over to access the screws for the rear facing camera.
    • Be very careful that you doe not tear the wires for the camera. gently flip the motherboard making sure to not stress out the wires.
    Pergunte ao FixBot
    Comentar
  10. Envizen V100M Motherboard Replacement: passo 10, imagem 1 %32 Envizen V100M Motherboard Replacement: passo 10, imagem 2 %32
    • Unscrew the camera from the back of the motherboard using the ifixt PH00 screwdriver.
    • Gently push on the black plastic bracket holding the camera in place. The bracket should pop right out.
    • The screws for mounting bracket are also 1.5mm diameter and 3.5mm long.
    Pergunte ao FixBot
    Comentar
  11. Envizen V100M Motherboard Replacement: passo 11, imagem 1 %32 Envizen V100M Motherboard Replacement: passo 11, imagem 2 %32
    • Now the motherboard is completely removed from the tablet.
    • Place the motherboard in a static-free location
    Pergunte ao FixBot
    Comentar
Conclusão
nbach
Membro desde: 03/23/15
663 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 3-2, Duarte Spring 2015 Membro de UMass Dartmouth, Team 3-2, Duarte Spring 2015
UMASSD-DUARTE-S15S3G2
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 1,417
