Ir para o conteúdo principal
Ematic FunTab 3 Motherboard Replacement
O que você precisa
    1. Ematic FunTab 3 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement, Back Panel: passo 1, imagem 2 %32 Ematic FunTab 3 Motherboard Replacement, Back Panel: passo 1, imagem 3 %32
      • Turn off the device before starting
      • To prevent damage, open the device on the side without the buttons.
      • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
      • Slide the plastic opening tool down the long side of the device.
      • Insert tool again and slide it down the long slide of the case a second time.
      Pergunte ao FixBot
      Comentar
    2. Ematic FunTab 3 Motherboard Replacement: passo 2, imagem 1 %32
      • Pull the back panel away from the screen.
      Pergunte ao FixBot
      Comentar
    1. Ematic FunTab 3 Motherboard Replacement, Battery: passo 3, imagem 1 %32
      • Remove the black tape to reveal the wire ribbon connector.
      Pergunte ao FixBot
      Comentar
    2. Ematic FunTab 3 Motherboard Replacement: passo 4, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 4, imagem 2 %32 Ematic FunTab 3 Motherboard Replacement: passo 4, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Flip up the black retaining tab using the plastic opening tool.
      • Pull out the large wire ribbon that crosses over the battery.
      • You may need tweezers to pull out the wire ribbon.
      Pergunte ao FixBot
      Comentar
    3. Ematic FunTab 3 Motherboard Replacement: passo 5, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 5, imagem 2 %32 Ematic FunTab 3 Motherboard Replacement: passo 5, imagem 3 %32
      • Insert the plastic opening tool under the battery.
      • Using the plastic opening tool, pry up the battery.
      • There is tape on the back of the battery. Some more force may be required to separate the battery from the back of the display.
      Pergunte ao FixBot
      Comentar
    4. Ematic FunTab 3 Motherboard Replacement: passo 6, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 6, imagem 2 %32
      • Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
      • After the connections are desoldered, remove the battery.
      • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
      Pergunte ao FixBot
      Comentar
    1. Ematic FunTab 3 Motherboard Replacement, Speaker: passo 7, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement, Speaker: passo 7, imagem 2 %32
      Pergunte ao FixBot
      Comentar
    2. Ematic FunTab 3 Motherboard Replacement: passo 8, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 8, imagem 2 %32 Ematic FunTab 3 Motherboard Replacement: passo 8, imagem 3 %32
      • After the connections are desoldered, remove the speaker by prying it up using a plastic opening tool.
      • There is glue on the back of the speaker. Some more force may be required.
      Pergunte ao FixBot
      Comentar
    1. Ematic FunTab 3 Motherboard Replacement, Camera: passo 9, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement, Camera: passo 9, imagem 2 %32
      Pergunte ao FixBot
      Comentar
    2. Ematic FunTab 3 Motherboard Replacement: passo 10, imagem 1 %32
      • Use the plastic opening tool to flip up the black retaining tab.
      Pergunte ao FixBot
      Comentar
    3. Ematic FunTab 3 Motherboard Replacement: passo 11, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 11, imagem 2 %32
      • Pull out the wire ribbon connected to the camera.
      • The camera is held in place by glue, so extra force may be required.
      • Remove the camera from the device.
      Pergunte ao FixBot
      Comentar
    1. Ematic FunTab 3 Motherboard Replacement, Motherboard: passo 12, imagem 1 %32
      • Remove the black tape to reveal the screen connector.
      Pergunte ao FixBot
      Comentar
    2. Ematic FunTab 3 Motherboard Replacement: passo 13, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 13, imagem 2 %32
      • Flip up the retaining tab using the plastic opening tool.
      • Pull out the screen wire ribbon to disconnect the screen and motherboard.
      Pergunte ao FixBot
      Comentar
    3. Ematic FunTab 3 Motherboard Replacement: passo 14, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 14, imagem 2 %32
      • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
      Pergunte ao FixBot
      Comentar
    4. Ematic FunTab 3 Motherboard Replacement: passo 15, imagem 1 %32
      • It is now safe to remove and replace the old motherboard with your new motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Amanda Davis
Membro desde: 07/11/18
581 Reputação
Autoria de 5 guias
Equipe
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Membro de UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 633
