Ir para o conteúdo principal
Ematic FunTab 2 Battery Replacement
O que você precisa
    1. Ematic FunTab 2 Battery Replacement, Battery: passo 1, imagem 1 %32 Ematic FunTab 2 Battery Replacement, Battery: passo 1, imagem 2 %32
      • Pry open the Ematic FunTab 2 using the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    2. Ematic FunTab 2 Battery Replacement: passo 2, imagem 1 %32
      • Remove tape from the LCD connector.
      Pergunte ao FixBot
      Comentar
    3. Ematic FunTab 2 Battery Replacement: passo 3, imagem 1 %32 Ematic FunTab 2 Battery Replacement: passo 3, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Flip up the retaining tab (the black bar on the connector), then pull LCD connector with tweezers. Be careful not to damage the LCD connector.
      Pergunte ao FixBot
      Comentar
    4. Ematic FunTab 2 Battery Replacement: passo 4, imagem 1 %32 Ematic FunTab 2 Battery Replacement: passo 4, imagem 2 %32 Ematic FunTab 2 Battery Replacement: passo 4, imagem 3 %32
      • Now remove battery by putting the spudger between the battery and the LCD display and prying apart.
      • Be careful when prying the battery from the display. Wiggle the spudger if necessary.
      Pergunte ao FixBot
      Comentar
    5. Ematic FunTab 2 Battery Replacement: passo 5, imagem 1 %32
      • Remove tape from the yellow, red, and black wires connecting the battery to the LCD.
      Pergunte ao FixBot
      Comentar
    6. Ematic FunTab 2 Battery Replacement: passo 6, imagem 1 %32 Ematic FunTab 2 Battery Replacement: passo 6, imagem 2 %32 Ematic FunTab 2 Battery Replacement: passo 6, imagem 3 %32
      • Disconnect the yellow, red, and black wires from the motherboard.
      • You will need to solder these wires back after completing the battery replacement. Here is a link on how to solder Como soldar e dessoldar contatos.
      Pergunte ao FixBot
      Comentar
    7. Ematic FunTab 2 Battery Replacement: passo 7, imagem 1 %32
      • Now remove battery. The battery should still be pried from the LCD display, if not pry it again.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 40
Ao todo: 2,779
