Ir para o conteúdo principal
Dyson V8 Animal Battery Replacement
O que você precisa
    1. Dyson V8 Animal Battery Replacement, Bin: passo 1, imagem 1 %32 Dyson V8 Animal Battery Replacement, Bin: passo 1, imagem 2 %32
      • Push the red button and slide the connecting shaft off.
      • The shaft must be held from moving when disconnecting from the motor.
      Pergunte ao FixBot
      Comentar
    2. Dyson V8 Animal Battery Replacement: passo 2, imagem 1 %32 Dyson V8 Animal Battery Replacement: passo 2, imagem 2 %32 Dyson V8 Animal Battery Replacement: passo 2, imagem 3 %32
      • Pull up on the red tab and continue to slide the motor completely up.
      • The dust bin will open on the bottom.
      Pergunte ao FixBot
      Comentar
    3. Dyson V8 Animal Battery Replacement: passo 3, imagem 1 %32 Dyson V8 Animal Battery Replacement: passo 3, imagem 2 %32
      • Push the red tab down.
      • Pull the dust bin out from the handle head.
      Pergunte ao FixBot
      Comentar
    1. Dyson V8 Animal Battery Replacement, Battery: passo 4, imagem 1 %32 Dyson V8 Animal Battery Replacement, Battery: passo 4, imagem 2 %32
      • Push down on the red tab.
      Pergunte ao FixBot
      Comentar
    2. Dyson V8 Animal Battery Replacement: passo 5, imagem 1 %32 Dyson V8 Animal Battery Replacement: passo 5, imagem 2 %32
      • Push down on the red tab on the other side.
      • Pull the motor away from the handle.
      • You may need to hold down the handle while sliding the motor off.
      Pergunte ao FixBot
      Comentar
    3. Dyson V8 Animal Battery Replacement: passo 6, imagem 1 %32 Dyson V8 Animal Battery Replacement: passo 6, imagem 2 %32
      • Use a Phillips #0 screwdriver to remove two 18 mm screws on the bottom of the battery.
      Pergunte ao FixBot
      Comentar
    4. Dyson V8 Animal Battery Replacement: passo 7, imagem 1 %32
      • Use a Phillips #0 screwdriver to remove one 18 mm screw on the back of the handle.
      Pergunte ao FixBot
      Comentar
    5. Dyson V8 Animal Battery Replacement: passo 8, imagem 1 %32 Dyson V8 Animal Battery Replacement: passo 8, imagem 2 %32
      • Slide the battery out from handle.
      • The handle must be held from moving while sliding the battery out.
      Pergunte ao FixBot
      Comentar
Conclusão
20 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S19-G1, White Winter 2020 Membro de Cal Poly, Team S19-G1, White Winter 2020
CPSU-WHITE-W20S19G1
4 Membros
Autoria de 18 guias
9Comentários do guia
Replacement Vacuum Cleaner Batteries for Dyson V8 Animal
Battery Type:   Li-ion
Voltage:   21.6V
Capacity:   4000mAh
Color:   Grey
Weight:   770.26g
Dimensions: 145.00 x 90.10 x 115.90mm
If you intereted in this battery, please view more info on http://www.drillbattery.com.au/orderbatt...
Drillbatterycomau - Responder Compartilhar
Thankyou! I'll be able to replace the battery soon.
Olivia Swift - Responder Compartilhar
This worked for the V7 Animal model just fine. Very easy and clear, thank you!
Katie - Responder Compartilhar
Thank you. These instructions just helped me to replace the worn out battery on our V8 Animal in 5 minutes! Now it's humming along again with 3 blue bars. Great! (Note: I was concerned I might strip the screw head but I just pressed harder while turning and the screwdriver did not slip. Then I saw that the replacement battery came with four new replacement screws. So, it's all good.)
Neill Graham - Responder Compartilhar
I have a stripped screw that won't extract. I have already drilled the hole ho so now no screwdriver will work. Any suggestions?
christina - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 55
Últimos 30 dias: 320
Ao todo: 13,848
