Ir para o conteúdo principal
Dyson Corrale HS03 Battery Replacement
O que você precisa
    1. Dyson Corrale HS03 Battery Replacement, Outer Casing: passo 1, imagem 1 %32 Dyson Corrale HS03 Battery Replacement, Outer Casing: passo 1, imagem 2 %32
      • Hold the Dyson with the silver safety lock facing you and push it upward.
      • This opens the heating plates forming a "V."
      Pergunte ao FixBot
      Comentar
    2. Dyson Corrale HS03 Battery Replacement: passo 2, imagem 1 %32 Dyson Corrale HS03 Battery Replacement: passo 2, imagem 2 %32 Dyson Corrale HS03 Battery Replacement: passo 2, imagem 3 %32
      • Use a TR6 Torx security screwdriver to remove the screw from the center of the purple hinge bracket on each side of the hinge.
      • Use a Jimmy or spudger to carefully pry up and remove the hinge brackets.
      Pergunte ao FixBot
      Comentar
    3. Dyson Corrale HS03 Battery Replacement: passo 3, imagem 1 %32 Dyson Corrale HS03 Battery Replacement: passo 3, imagem 2 %32 Dyson Corrale HS03 Battery Replacement: passo 3, imagem 3 %32
      • Pull off the black cover from the base.
      • Use a TR7 Torx security screwdriver to remove the two screws from the base of the straightener.
      Pergunte ao FixBot
      Comentar
    4. Dyson Corrale HS03 Battery Replacement: passo 4, imagem 1 %32 Dyson Corrale HS03 Battery Replacement: passo 4, imagem 2 %32
      • With your thumb and index fingers, pull the black charging port cover off.
      Pergunte ao FixBot
      Comentar
    5. Dyson Corrale HS03 Battery Replacement: passo 5, imagem 1 %32 Dyson Corrale HS03 Battery Replacement: passo 5, imagem 2 %32 Dyson Corrale HS03 Battery Replacement: passo 5, imagem 3 %32
      • Hold the Dyson firmly, supporting one side with one hand while using the other hand to open the opposite side.
      • Pull up on the side you want to open to release it, then repeat on the opposite side.
      Pergunte ao FixBot
      Comentar
    6. Dyson Corrale HS03 Battery Replacement: passo 6, imagem 1 %32 Dyson Corrale HS03 Battery Replacement: passo 6, imagem 2 %32
      • Use a T4 Torx screwdriver to remove the screws from the middle section.
      Pergunte ao FixBot
      Comentar
    7. Dyson Corrale HS03 Battery Replacement: passo 7, imagem 1 %32
      • Use an opening tool to pop off the silver safety lock.
      Pergunte ao FixBot
      Comentar
    8. Dyson Corrale HS03 Battery Replacement: passo 8, imagem 1 %32 Dyson Corrale HS03 Battery Replacement: passo 8, imagem 2 %32 Dyson Corrale HS03 Battery Replacement: passo 8, imagem 3 %32
      • Hold the Dyson firmly with one hand. With the other hand, push down under the black tab while pulling up at the same time to lift and remove the purple casing.
      Pergunte ao FixBot
      Comentar
    1. Dyson Corrale HS03 Battery Replacement, Battery: passo 9, imagem 1 %32 Dyson Corrale HS03 Battery Replacement, Battery: passo 9, imagem 2 %32 Dyson Corrale HS03 Battery Replacement, Battery: passo 9, imagem 3 %32
      • Pull the purple casing upward to access and remove the battery.
      • Use a TR7 Torx security screwdriver to remove the screw securing the magnetic charging port.
      • Detach the charging port.
      • When removing it, avoid pulling as it is attached to the device by a white cable.
      Pergunte ao FixBot
      Comentar
    2. Dyson Corrale HS03 Battery Replacement: passo 10, imagem 1 %32 Dyson Corrale HS03 Battery Replacement: passo 10, imagem 2 %32 Dyson Corrale HS03 Battery Replacement: passo 10, imagem 3 %32
      • With a TR6 Torx security screwdriver, you will take off a singular screw.
      • This will later be an advantage when removing the black cover of the control board.
      Pergunte ao FixBot
      Comentar
    3. Dyson Corrale HS03 Battery Replacement: passo 11, imagem 1 %32 Dyson Corrale HS03 Battery Replacement: passo 11, imagem 2 %32 Dyson Corrale HS03 Battery Replacement: passo 11, imagem 3 %32
      • Use a spudger or a clean fingernail to flip up the black locking flap highlighted by the red circle—in the last photo, it is in the unlocked position.
      • Use tweezers or your fingers to gently pull the white ribbon cable from the socket on the board.
      Pergunte ao FixBot
      Comentar
    4. Dyson Corrale HS03 Battery Replacement: passo 12, imagem 1 %32 Dyson Corrale HS03 Battery Replacement: passo 12, imagem 2 %32 Dyson Corrale HS03 Battery Replacement: passo 12, imagem 3 %32
      • Use an iFixit opening tool, to remove the black cover, which should pop right out.
      • Use the iFixit opening tool, to take off the plastic cover leading to the control panel.
      Pergunte ao FixBot
      Comentar
    5. Dyson Corrale HS03 Battery Replacement: passo 13, imagem 1 %32 Dyson Corrale HS03 Battery Replacement: passo 13, imagem 2 %32
      • Once again, with an iFixit opening tool, take the black cover off, revealing the side part of the battery.
      Pergunte ao FixBot
      Comentar
    6. Dyson Corrale HS03 Battery Replacement: passo 14, imagem 1 %32 Dyson Corrale HS03 Battery Replacement: passo 14, imagem 2 %32
      • The Control panel will be removed using a ifixit opening tool
      • The plastic cover should now come off by simply grabbing it from the top and taking it off.
      Pergunte ao FixBot
      Comentar
    7. Dyson Corrale HS03 Battery Replacement: passo 15, imagem 1 %32 Dyson Corrale HS03 Battery Replacement: passo 15, imagem 2 %32 Dyson Corrale HS03 Battery Replacement: passo 15, imagem 3 %32
      • Use a TR7 Torx Security Screwdriver to remove the single screw shown in the picture.
      • This now gives you a clear view of the batteries and what you'll need for your next step.
      Pergunte ao FixBot
      Comentar
    8. Dyson Corrale HS03 Battery Replacement: passo 16, imagem 1 %32 Dyson Corrale HS03 Battery Replacement: passo 16, imagem 2 %32
      • Use a iFixit Opening Tool to remove the battery holder. Be careful, as this step can be a bit challenging.
      • Repeat this on all eight sides. Once you finish, the batteries should fall out on their own.
      • Replacing the 4-cell lithium-ion battery pack requires spot welding. For more information on this process, check out this article.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
4Comentários do guia
Has anyone done this and it work? I’ve heard the new batteries have to be just right for the system to accept them
Michael van der Lubbe - Responder Compartilhar
Laut meinem Research sind es 18650 Akkus mit 3,7V 2200mAh
Werde auch ein defektes Gerät besorgen und versuchen zu reparieren.
Benjamin K. - Responder Compartilhar
Hab die Akkus getauscht, hat alles geklappt. Aber jetzt blinkt die An/Aus Taste nur lurz ganz schnell und nichts passiert. Was nun?
Daniel Thomaschewsky - Responder Compartilhar
@danielthom15017 It's nothing anymore, he became a brick
Dyson Service Center - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 25
Últimos 7 dias: 191
Últimos 30 dias: 996
Ao todo: 8,173
