Ir para o conteúdo principal
DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement
O que você precisa
  1. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Check your controller model: passo 1, imagem 1 %32
    • Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
    • If you have the second generation DualShock 4, model CUH-ZCT2U, use these guides.
  2. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Unfasten the rear case: passo 2, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Unfasten the rear case: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • If you need to stabilize your controller during this repair, lay it on a soft surface such as a microfiber cloth.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
    to re-torque these PH00 screw... i found 19Ncm to be about the max. (since 27Ncm was too much)
    Dreamcat 4 - Responder
  3. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the L1 button: passo 3, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the L1 button: passo 3, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the L1 button: passo 3, imagem 3 %32
    • Use an opening pick to pry each corner of the L1 button from the front case.
    • Cover the button to prevent it from ejecting out of your workspace.
    • Remove the button.
  4. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the R1 button: passo 4, imagem 1 %32
    • Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
  5. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Unclip the rear case: passo 5, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Unclip the rear case: passo 5, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Unclip the rear case: passo 5, imagem 3 %32
    • Six plastic clips secure the rear case to the front case. The next four steps demonstrate how to release these clips before you can open the controller.
    • Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
    • Slide your pick toward the handle and pry up to release the first clip.
    • Repeat this procedure on the other side of the controller to release the second clip.
  6. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 6, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 6, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 6, imagem 3 %32
    • Two more clips secure the rear case near the extension port and the headphone jack.
    • Insert your opening pick between the front case and rear case at either side of the ports.
    • Twist your pick to unclip this section of the rear case from the front case.
    • If the rear case feels stuck, insert and twist your pick from different angles.
    • Don't open the controller yet, as it's still held together by two very delicate clips near the triggers.
  7. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 7, imagem 1 %32
    • The final two clips are very delicate, and must be disengaged from inside the controller. If you break them, don't worry—it won't affect this repair or your controllers functionality.
    • Locate the clips by looking through the gap above the R2 or L2 buttons.
  8. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 8, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 8, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 8, imagem 3 %32
    • Insert the point of a spudger through the gap above the R2 button and push the retaining clip outward.
    • While pushing the clip outward, slowly pull the rear case away from the front case until you feel them separate.
    • Don't fully open the controller until each of the R2 and L2 clips have been disengaged.
    • Repeat this procedure for the clip near the L2 button.
  9. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the rear case: passo 9, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the rear case: passo 9, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the rear case: passo 9, imagem 3 %32
    • Press the R2 button and slide the rear case over it.
  10. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 10, imagem 1 %32
    • Press the L2 button and slide the rear case over it.
  11. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 11, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 11, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 11, imagem 3 %32
    • Flip the rear case over the top of the controller and lay it down, being careful not to strain the interconnect cable.
  12. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the interconnect cable: passo 12, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the interconnect cable: passo 12, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the interconnect cable: passo 12, imagem 3 %32
    • Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
    • During reassembly, reconnect the cable with its blue pull tab facing the outside of the controller.
    On the model CUH-ZCT2E the circuit board is mirrored so that the connection is on the left side. When reassembling the blue tab should be facing inwards.
    Konrad Skeri Ekblad - Responder
  13. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the battery: passo 13, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the battery: passo 13, imagem 2 %32
    • Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
    • Only pull on the head of the connector—don't pull on the cable itself.
  14. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the battery: passo 14, imagem 1 %32
    • Remove the battery.
  15. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the reset button extension: passo 15, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the reset button extension: passo 15, imagem 2 %32
    • Grab and remove the reset button extension from its recess in the battery bracket.
    On the model CUH-ZCT2E this is part of the battery bracket and not removable. Just skip this step.
  16. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the battery bracket: passo 16, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the battery bracket: passo 16, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the battery bracket: passo 16, imagem 3 %32
    • Locate the two clips securing the battery bracket to the motherboard.
    • Insert the point of your spudger into the opening behind the right bracket clip.
    • Depress the clip to disengage it from the motherboard.
    • Lift up the right edge of the battery bracket.
    On the model CUH-ZCT2E the battery bracket is not secured by clips but by a PH #00 screw mid height on the right half of the battery bracket. Just remove the screw and for the next step lift the battery bracket straight up.
  17. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 17, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 17, imagem 2 %32
    • Insert the point of your spudger in the opening behind the left bracket clip.
    • Remove the battery bracket.
  18. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the touch pad: passo 18, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the touch pad: passo 18, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the touch pad: passo 18, imagem 3 %32
    • Use the point of your spudger to flip up the locking flap securing the touch pad cable ZIF connector.
    • Use tweezers or your fingers to disconnect the cable using its blue pull tab.
  19. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Unfasten the motherboard: passo 19, imagem 1 %32
    • Use your Phillips screwdriver to remove the 6.4 mm screw securing the motherboard.
    • During reassembly, hold the motherboard tight to the front case before fastening it. Test each button to ensure the silicone button pads are properly aligned. If each button presses as expected, fasten the motherboard.
    On the model CUH-ZCT2E this screw was removed in step 16. Just skip this step.
  20. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the midframe: passo 20, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the midframe: passo 20, imagem 2 %32
    • Grab the midframe by its plastic protrusions or the vibration motors and remove it.
    • Be careful not to separate the motherboard from the midframe, as they're only connected to each other by the vibration motor cables.
    • During reassembly, take your time positioning the midframe. Use the alignment posts to help guide it into place, and make sure the touch pad cable doesn't become trapped underneath.
  21. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the motherboard: passo 21, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the motherboard: passo 21, imagem 2 %32
    • Be careful not to strain the vibration motor cables. Follow this guide to re-solder the vibration motors if they break off the motherboard.
    • Lift the motherboard and flip it over the bottom of the midframe, leaving the vibration motor cables attached.
  22. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the R2 button: passo 22, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the R2 button: passo 22, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the R2 button: passo 22, imagem 3 %32
    • Firmly grip the R2 button and unclip each peg from the midframe.
    • The spring may eject from the inside peg. Be careful not to lose it.
    • Remove the R2 button.
    de haut en bas ou comment
    Amadou Garango - Responder
  23. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the L2 button: passo 23, imagem 1 %32
    • Unclip the L2 button from the midframe and remove it, making sure not to lose the small spring from the inside peg.
  24. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Reassembly information: passo 24, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Reassembly information: passo 24, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Reassembly information: passo 24, imagem 3 %32
    • During reassembly, follow these instructions to install the springs onto the R2 and L2 buttons:
    • Lay the midframe face-down and orient the button properly.
    • Place the spring over the inside peg with its bent ends facing upward.
    • Rest one end of the spring in its channel in the button.
    • Place the button over its clips and rest the other end of the spring in its channel in the midframe.
    • Press the button's pegs into their clips until they snap into place.
  25. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the silicone button pads: passo 25, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the silicone button pads: passo 25, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the silicone button pads: passo 25, imagem 3 %32
    • Grab the upper edge of the R1 and R2 button pad.
    • Slide the pad out of its channel in the midframe.
  26. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 26, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 26, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 26, imagem 3 %32
    • Slide the L1 and L2 button pad out of its channel in the midframe and remove it.
    • Each pad has two plugs and an upper groove to align it with the midframe. During reassembly, ensure the plugs are inserted in their holes and the groove is hooked onto the tab in the midframe.
  27. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Loosen the button circuit membrane: passo 27, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Loosen the button circuit membrane: passo 27, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Loosen the button circuit membrane: passo 27, imagem 3 %32
    • Use tweezers or the point of a spudger to lift the underside of the R1 and R2 section of the button circuit membrane.
    • Slide the membrane over its retaining tab on the midframe.
    • During reassembly, slide the membrane into its slot until it snaps into place over its retaining tab.
  28. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 28, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 28, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 28, imagem 3 %32
    • Use tweezers or the point of a spudger to lift the underside of the L1 and L2 section of the button circuit membrane.
  29. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 29, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 29, imagem 2 %32
    • Peel and lift the middle section of the button circuit membrane from its retaining pegs on the back of the midframe.
  30. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 30, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 30, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 30, imagem 3 %32
    • Flip the midframe over so the button circuit membrane is facing you.
    • Unclip the right half of the button circuit membrane from its two retaining pegs on the face of the midframe.
  31. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 31, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 31, imagem 2 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: passo 31, imagem 3 %32
    • Unclip the left half of the button circuit membrane from its two retaining pegs on the face of the midframe.
  32. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the button circuit membrane: passo 32, imagem 1 %32 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the button circuit membrane: passo 32, imagem 2 %32
    • Grab each side of the button circuit membrane.
    • Feed the middle section of the membrane through its cutout in the midframe.
    • Remove the membrane.
Conclusão
11 outras pessoas executaram este guia.
Clay Eickemeyer
Membro desde: 09/19/22
66.811 Reputação
Autoria de 453 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.198 guias
9 comentários
I’ve changed two flex boards from two different sellers, and I keep having a battery drain of about 25mA after i installed them. The battery drain is not present with the original flex board, any ideas?
Alessandro - Responder
Ok no, little update. the battery drain is present even if I disconnect the flex board, the touch connector and the led . It’s something on the main board I think, but I can’t figure out what is it. Is there some insulation that I may have lost when changing the flex board the first time?
Alessandro -
That sounds really weird. I don’t remember any insulation on this specific model of controller. I don’t have this anymore as it was a repair for a friend and I also hadn’t noticed or measured such a drain.
Devnol -
The only other thing I can think of is a failure on one of the components soldered on the main board, but 20mA in standby condition are VERY high!
The warning regarding the rumblers being hard soldered and the wiring is delicate honestly should be in step 4, jiggling joysticks to remove the front cover can easily cause the rumblers to be disconnected and require some time consuming resoldering to reattach them.
sefog - Responder
Good point! From the fact that I used the word "again" in step 6, I may have had that in at some point but something happened and I accidentally removed it. I'll add it back. Thanks a lot for the feedback!
Devnol -
As of March 14, 2023, this guide has been updated! Comments regarding step procedures may no longer be relevant.
Clay Eickemeyer - Responder
Buenos días. En mi caso cambie el flex, cambie las gomitas conductoras y así y todo sigue sin funcionar el R2. Sabrán cuál es el problema???
Andres Juan Arana - Responder
Hi! I'm sorry your R2 button doesn't work. You have some options. 1) Look for damage on the silicone button pad. Make sure the R2 button can push the pad onto the button circuit membrane. Look for damage that prevents the button from pressing. 2) Clean the silicone pad where it touches the button circuit membrane. Dirt or dust might block the connection. 3) Follow the connection on the button circuit membrane to where it connects to the motherboard. Clean the contact on the motherboard and look for electrical damage.
If you have more questions, ask the community!
Good luck!
Clay Eickemeyer -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 15
Últimos 7 dias: 107
Últimos 30 dias: 501
Duração total: 26,244
