Ir para o conteúdo principal
Drill Master Heat Gun Power Switch Replacement
O que você precisa
    1. Drill Master Heat Gun Power Switch Replacement, Power Switch: passo 1, imagem 1 %32
      • Be sure the heat gun is unplugged before starting this process.
      • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
      • You will need a screwdriver extension.
      Pergunte ao FixBot
      Comentar
    2. Drill Master Heat Gun Power Switch Replacement: passo 2, imagem 1 %32
      • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
      • Don't try to open the casing just yet.
      Pergunte ao FixBot
      Comentar
    3. Drill Master Heat Gun Power Switch Replacement: passo 3, imagem 1 %32 Drill Master Heat Gun Power Switch Replacement: passo 3, imagem 2 %32 Drill Master Heat Gun Power Switch Replacement: passo 3, imagem 3 %32
      • Remove the barrel casing on either end by twisting and pulling each side off.
      Pergunte ao FixBot
      Comentar
    4. Drill Master Heat Gun Power Switch Replacement: passo 4, imagem 1 %32
      • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
      Pergunte ao FixBot
      Comentar
    5. Drill Master Heat Gun Power Switch Replacement: passo 5, imagem 1 %32
      • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
      • Screws do not come out of connector.
      Pergunte ao FixBot
      Comentar
    6. Drill Master Heat Gun Power Switch Replacement: passo 6, imagem 1 %32
      • Squeeze the tabs on either side of the power switch to remove from the casing.
      Pergunte ao FixBot
      Comentar
    7. Drill Master Heat Gun Power Switch Replacement: passo 7, imagem 1 %32 Drill Master Heat Gun Power Switch Replacement: passo 7, imagem 2 %32
      • Remove the black, plastic wire protectors from the end of the power switch.
      Pergunte ao FixBot
      Comentar
    8. Drill Master Heat Gun Power Switch Replacement: passo 8, imagem 1 %32
      • Use soldering iron to remove the electrical wiring from the power switch. To replace the power switch, solder the new switch onto the wires.
      • Heating the soldering metal will allow you to pull off the electrical wiring.
      • For a brush-up on proper soldering, check out How to Solder and Desolder Connections.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 52
Ao todo: 3,993
