Ir para o conteúdo principal
Drawstring Bag Tab Replacement
O que você precisa
    1. Drawstring Bag Tab Replacement, Drawstring Bag Tab: passo 1, imagem 1 %32 Drawstring Bag Tab Replacement, Drawstring Bag Tab: passo 1, imagem 2 %32 Drawstring Bag Tab Replacement, Drawstring Bag Tab: passo 1, imagem 3 %32
      • Using your pen and ruler, draw two strips of 3.5" x 0.5" pieces of cloth.
      • Cut those two strips with your scissors.
      Pergunte ao FixBot
      Comentar
    2. Drawstring Bag Tab Replacement: passo 2, imagem 1 %32
      • Align your two strips back to back.
      • Use two sewing pins to hold the strips in place for easy alignment during the sewing process.
      • Carefully handle the pins to avoid accidental punctures or injury. Use a thimble if needed.
      Pergunte ao FixBot
      Comentar
    3. Drawstring Bag Tab Replacement: passo 3, imagem 1 %32 Drawstring Bag Tab Replacement: passo 3, imagem 2 %32 Drawstring Bag Tab Replacement: passo 3, imagem 3 %32
      • Using your thread and sewing needle, sew along the long edge in a straight line using a straight stitch.
      • Use a seam allowance of 1/8"
      • Repeat on the other side.
      • Carefully handle the needle to avoid accidental punctures or injury. Use a thimble if neede.
      Pergunte ao FixBot
      Comentar
    4. Drawstring Bag Tab Replacement: passo 4, imagem 1 %32 Drawstring Bag Tab Replacement: passo 4, imagem 2 %32
      • Fold your strip around the cord to your drawstring bag to create a loop.
      Pergunte ao FixBot
      Comentar
    5. Drawstring Bag Tab Replacement: passo 5, imagem 1 %32 Drawstring Bag Tab Replacement: passo 5, imagem 2 %32 Drawstring Bag Tab Replacement: passo 5, imagem 3 %32
      • Using the whipstitch technique, sew the two ends together.
      • Carefully handle the needle to avoid accidental punctures or injury. Use a thimble if needed.
      Pergunte ao FixBot
      Comentar
    6. Drawstring Bag Tab Replacement: passo 6, imagem 1 %32 Drawstring Bag Tab Replacement: passo 6, imagem 2 %32 Drawstring Bag Tab Replacement: passo 6, imagem 3 %32
      • Take the sewn ends and insert them 1/4" into the ripped hole where the original tab was.
      Pergunte ao FixBot
      Comentar
    7. Drawstring Bag Tab Replacement: passo 7, imagem 1 %32 Drawstring Bag Tab Replacement: passo 7, imagem 2 %32 Drawstring Bag Tab Replacement: passo 7, imagem 3 %32
      • Align the fabric with the seam line.
      • Using the whipstitch technique, sew it to the bag from the outside ensuring the stitches are along the seam.
      Pergunte ao FixBot
      Comentar
    8. Drawstring Bag Tab Replacement: passo 8, imagem 1 %32 Drawstring Bag Tab Replacement: passo 8, imagem 2 %32
      • Now you have a working drawstring bag!
      Pergunte ao FixBot
      Comentar
Linha de Chegada
Ava Overton
Membro desde: 02/19/25
157 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-1, Andersen Winter 2025 Membro de UC Davis, Team 3-1, Andersen Winter 2025
UCD-ANDERSEN-W25S3G1
3 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 40
Ao todo: 610
