Ir para o conteúdo principal
Dragon Touch Y88X Plus Battery Replacement
O que você precisa
    1. Dragon Touch Y88X Plus Battery Replacement, Battery: passo 1, imagem 1 %32
      • Remove the back case using a plastic opening tool or spudger.
      • Start at the corners and work your way around the perimeter of the tablet.
      • Be gentle to avoid damaging the case or any internal components.
      Pergunte ao FixBot
      Comentar
    2. Dragon Touch Y88X Plus Battery Replacement: passo 2, imagem 1 %32 Dragon Touch Y88X Plus Battery Replacement: passo 2, imagem 2 %32
      • Identify the tablet's battery. It is usually a flat, rectangular component connected to the motherboard.
      • Carefully peel the old battery from the adhesive using your iFixit pry tool.
      • Be very cautious not to puncture the battery if yours has expanded . If the battery is swollen, read the article on What to do with a swollen battery for assistance.
      Pergunte ao FixBot
      Comentar
    3. Dragon Touch Y88X Plus Battery Replacement: passo 3, imagem 1 %32 Dragon Touch Y88X Plus Battery Replacement: passo 3, imagem 2 %32
      • Use a soldering iron to disconnect each connector individually from the motherboard.
      Pergunte ao FixBot
      Comentar
    4. Dragon Touch Y88X Plus Battery Replacement: passo 4, imagem 1 %32
      • Remove any adhesive from the battery.
      • Remove the battery.
      Pergunte ao FixBot
      Comentar
Conclusão
Bavly Aziz
Membro desde: 10/30/23
195 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-4, Petersen Fall 2023 Membro de UMass Dartmouth, Team 1-4, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G4
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 26
Ao todo: 476
