Ir para o conteúdo principal
Disassembling Logitech MBJ58 Mouse Scroll wheel from mount
O que você precisa
    1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Top cover: passo 1, imagem 1 %32
      • Hold the mouse so that the bottom is facing up.
      • Remove the single Phillips #1 screw from the bottom half of the mouse.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 2, imagem 1 %32 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 2, imagem 2 %32
      • Place the mouse so that the bottom is resting against a hard surface.
      • Lift the top cover of the mouse gently, and remove it.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, imagem 1 %32 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, imagem 2 %32 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, imagem 3 %32
      • Locate the scroll wheel on the mouse.
      • Grab the scroll wheel with your thumb and index finger.
      • Gently lift up, to remove the scroll wheel from the mouse.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: passo 4, imagem 1 %32 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: passo 4, imagem 2 %32
      • Locate the spring on the scroll wheel, and carefully remove the spring.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: passo 5, imagem 1 %32 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: passo 5, imagem 2 %32
      • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 6, imagem 1 %32 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 6, imagem 2 %32 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 6, imagem 3 %32
      • Use the images to locate where the resistance spring is.
      • This spring will easily fall off.
      • Grab the scroll wheel and its mount and gently pull them apart.
      Pergunte ao FixBot
      Comentar
Conclusão
14 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 5-14, Forte Winter 2013 Membro de Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Membros
Autoria de 23 guias
7Comentários do guia
Excellent! I took an MBJ58 apart to remove accumulated gunk, and the resistance spring jumped onto my worktable before I noticed where it came from. Thanks for the help, well done!
Marty Swartz - Responder Compartilhar
Heh, me too. Couldn't for the life of me figure out how it went back in. Thanks for the guide!
Steve Bennett - Responder Compartilhar
Same thing happened to me...saved me a trip to the store for a new mouse!!
thanks for taking the time to post these photos!
Bill McFarland - Responder Compartilhar
huh, thank you very much, amazing guide, the only for this product in Internet , and amazingly accurate
leartzajmi - Responder Compartilhar
the resistence spring falled off on mine how do i out it back on help
Tay Carr - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 62
Ao todo: 8,891
