Ir para o conteúdo principal
Disassembling JBL Tour Pro 3 case
O que você precisa
  1. Disassembling JBL Tour Pro 3 case, Top ring: passo 1, imagem 1 %32 Disassembling JBL Tour Pro 3 case, Top ring: passo 1, imagem 2 %32 Disassembling JBL Tour Pro 3 case, Top ring: passo 1, imagem 3 %32
    • Start by opening the case and removing the ring at the top by prying it off of the case
    Pergunte ao FixBot
    Comentar
  2. Disassembling JBL Tour Pro 3 case, Touchscreen: passo 2, imagem 1 %32
    • Now that the ring is off, heat up the touchscreen to loosen the adhesive behind it
    • Remove the touchscreen by using a prying pick to get in between the buds crevices and the touchscreen and pry it open just enough to press another pick in between the touchscreen and the case .
    • Use some isopropal alcohol to desolve the adhesive
    Pergunte ao FixBot
    Comentar
  3. Disassembling JBL Tour Pro 3 case, insides: passo 3, imagem 1 %32
    • Pry out the insides by using the prying picks in between the sides
    • Be careful for there is a cable attached to a daughter board which is screwed down at the bottom of the case.
    Pergunte ao FixBot
    Comentar
  4. Disassembling JBL Tour Pro 3 case, Daughter board: passo 4, imagem 1 %32 Disassembling JBL Tour Pro 3 case, Daughter board: passo 4, imagem 2 %32
    • Remove the 2 +0 size screws and pull out the daughter board
    Pergunte ao FixBot
    Comentar
Conclusão
Smokey
Membro desde: 01/06/26
109 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 12
Últimos 30 dias: 56
Ao todo: 249
