Ir para o conteúdo principal
Disassembling Fujifilm X30 Camera
O que você precisa
    1. Disassembling Fujifilm X30 Camera, Battery: passo 1, imagem 1 %32 Disassembling Fujifilm X30 Camera, Battery: passo 1, imagem 2 %32
      • Turn the camera upside down.
      • Place your thumb on the switch, and slide it towards the center of the camera.
      • The compartment will pop open.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Fujifilm X30 Camera: passo 2, imagem 1 %32
      • Once you have the battery compartment open, slide the orange tab away from the battery until it ejects.
      Pergunte ao FixBot
      Comentar
    3. Disassembling Fujifilm X30 Camera: passo 3, imagem 1 %32
      • Pull the battery out.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Fujifilm X30 Camera, Motherboard: passo 4, imagem 1 %32 Disassembling Fujifilm X30 Camera, Motherboard: passo 4, imagem 2 %32 Disassembling Fujifilm X30 Camera, Motherboard: passo 4, imagem 3 %32
      • Begin by removing the outside screws using a Phillips #000 Screwdriver:
      • Remove the three 3.6 mm silver screws located on the bottom of the camera.
      • Remove all four of the 4.7 mm screws from the sides of the camera.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Fujifilm X30 Camera: passo 5, imagem 1 %32 Disassembling Fujifilm X30 Camera: passo 5, imagem 2 %32
      • Remove all screws below using a Phillips #000 Screwdriver:
      • Lift up the screen and remove the two 4.5 mm screws located in the bottom corners.
      • Remove the 4.0 mm screw that is located behind the screen and directly under the eye piece.
      Pergunte ao FixBot
      Comentar
    3. Disassembling Fujifilm X30 Camera: passo 6, imagem 1 %32
      • Carefully lift up the bottom piece of the camera to remove it.
      • Be careful with delicate speaker wires attached to bottom.
      Pergunte ao FixBot
      Comentar
    4. Disassembling Fujifilm X30 Camera: passo 7, imagem 1 %32
      • Do not pull hard when removing the backing because it could rip the orange strip attached to the motherboard.
      • Gently pull off the back of the camera from the left side so that it is partially open.
      • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it
      • Refer to the next step to see pictures of how to properly use the spudger when removing a strip.
      Pergunte ao FixBot
      Comentar
    5. Disassembling Fujifilm X30 Camera: passo 8, imagem 1 %32 Disassembling Fujifilm X30 Camera: passo 8, imagem 2 %32 Disassembling Fujifilm X30 Camera: passo 8, imagem 3 %32
      • For all five indicated orange strips:
      • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it.
      Pergunte ao FixBot
      Comentar
    6. Disassembling Fujifilm X30 Camera: passo 9, imagem 1 %32
      • For the last orange strip located behind the top strip:
      Pergunte ao FixBot
      Comentar
    7. Disassembling Fujifilm X30 Camera: passo 10, imagem 1 %32
      • This step is required if you are doing a full disassembly, but can be skipped if you are only removing the motherboard.
      • For the two orange strips attached to the capacitor circuitboard:
      Pergunte ao FixBot
      Comentar
    8. Disassembling Fujifilm X30 Camera: passo 11, imagem 1 %32 Disassembling Fujifilm X30 Camera: passo 11, imagem 2 %32 Disassembling Fujifilm X30 Camera: passo 11, imagem 3 %32
      • Remove all screws listed below using a Phillips #000 screwdriver:
      • Remove the two 3.4 mm screws at the bottom of the silver plate.
      • Hold back the clear strip to reveal a 2.8 mm screw on the left of the silver plate and remove it.
      • Peel back the copper plate.
      Pergunte ao FixBot
      Comentar
    9. Disassembling Fujifilm X30 Camera: passo 12, imagem 1 %32
      • Remove the three 2.6 mm screws located in the top two corners and the bottom right corner of the motherboard using a Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    10. Disassembling Fujifilm X30 Camera: passo 13, imagem 1 %32 Disassembling Fujifilm X30 Camera: passo 13, imagem 2 %32
      • Tilt up the motherboard to locate the black, grey, and red wires.
      • Desolder these wires in order to completely remove the motherboard.
      • You can learn about soldering techniques here.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Fujifilm X30 Camera, Disassembling Fujifilm X30 Camera: passo 14, imagem 1 %32
      • Remove the four 4.4 mm silver screws at the corners of the lens using a Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Fujifilm X30 Camera: passo 15, imagem 1 %32 Disassembling Fujifilm X30 Camera: passo 15, imagem 2 %32
      • Pull the lens toward the bottom of the camera so it can clear the silver tab.
      • Then push the lens with your index fingers from the front of the camera until it is removed.
      Pergunte ao FixBot
      Comentar
    3. Disassembling Fujifilm X30 Camera: passo 16, imagem 1 %32 Disassembling Fujifilm X30 Camera: passo 16, imagem 2 %32
      • Do not touch the leads on the capacitor below the green circuitboard because they can shock you.
      • Remove the silver 3.4 mm screw from the top left corner of the capacitor circuitboard using a Phillips #000 screwdriver.
      • Desolder the red, black, grey, and green wires attached to the capacitor circuitboard so the circuitboard is disconnected and can be set aside.
      Pergunte ao FixBot
      Comentar
    4. Disassembling Fujifilm X30 Camera: passo 17, imagem 1 %32 Disassembling Fujifilm X30 Camera: passo 17, imagem 2 %32
      • Rotate the camera so you are looking at the bottom.
      • Remove the two silver 3.4 mm screws on the silver plate that are holding the eyepiece using a Phillips #000 screwdriver.
      • Lift the eyepiece out of the camera.
      Pergunte ao FixBot
      Comentar
    5. Disassembling Fujifilm X30 Camera: passo 18, imagem 1 %32 Disassembling Fujifilm X30 Camera: passo 18, imagem 2 %32
      • To remove the LCD screen, look at the back of the tiltable screen plate.
      • Remove the two black 3.7 mm screws in the back corners of the screen plate using a Phillips #000 screwdriver.
      • Lay the back panel flat to lift off the clear casing that is over the LCD screen.
      Pergunte ao FixBot
      Comentar
    6. Disassembling Fujifilm X30 Camera: passo 19, imagem 1 %32
      • You have disassembled the Fujifilm X30 camera!
      Pergunte ao FixBot
      Comentar
Conclusão
10 outras pessoas executaram este guia.
Jay Sterner
Membro desde: 01/12/16
470 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 70-3, Forte Winter 2016 Membro de Cal Poly, Team 70-3, Forte Winter 2016
CPSU-FORTE-W16S70G3
5 Membros
Autoria de 4 guias
2Comentários do guia
the big question is how to repair the common stuck open flash?
Don Makaveli - Responder Compartilhar
and the broken battery latch (orange tab)? Thanks.
yoyoy - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 127
Ao todo: 17,781
