Ir para o conteúdo principal
Dirt Devil Gator Motor Replacement
O que você precisa
  1. Dirt Devil Gator Motor Replacement, Motor: passo 1, imagem 1 %32
    • Press the button found at the top of the vacuum to separate the suction cup and the motor halves.
    Pergunte ao FixBot
    Comentar
  2. Dirt Devil Gator Motor Replacement: passo 2, imagem 1 %32 Dirt Devil Gator Motor Replacement: passo 2, imagem 2 %32 Dirt Devil Gator Motor Replacement: passo 2, imagem 3 %32
    • Pull apart the two halves to obtain the back half and set the front half aside
    Pergunte ao FixBot
    Comentar
  3. Dirt Devil Gator Motor Replacement: passo 3, imagem 1 %32 Dirt Devil Gator Motor Replacement: passo 3, imagem 2 %32 Dirt Devil Gator Motor Replacement: passo 3, imagem 3 %32
    • Unscrew each of the 13 mm screws with the micro screwdriver.
    • Once unscrewed, pull the case of the Dirt Devil Gator apart.
    Pergunte ao FixBot
    Comentar
  4. Dirt Devil Gator Motor Replacement: passo 4, imagem 1 %32 Dirt Devil Gator Motor Replacement: passo 4, imagem 2 %32 Dirt Devil Gator Motor Replacement: passo 4, imagem 3 %32
    • Pull out the grey switch and circuit board from its slot in the red case.
    • Remove all of the wires from the vacuum to where only the battery and wires are left.
    • Firmly pull out the battery and motor assembly. The circuit board and wires will remain attached.
    Pergunte ao FixBot
    Comentar
  5. Dirt Devil Gator Motor Replacement: passo 5, imagem 1 %32
    • Remove the motor from the Dirt Devil Gator exterior by pulling slightly on the white socket.
    • Replace it with a new motor by fitting the motor back into its socket.
    • Be cautious when handling the batteries and wires.
    • Keep the grey on-off switch in the "off" position to ensure a quick reassembly.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 13
Últimos 30 dias: 38
Ao todo: 902
