Ir para o conteúdo principal
DigiTech RP70 Input/Output ¼” Ports Replacement
O que você precisa
  1. DigiTech RP70 Input/Output ¼” Ports  Replacement, Motherboard: passo 1, imagem 1 %32 DigiTech RP70 Input/Output ¼” Ports  Replacement, Motherboard: passo 1, imagem 2 %32
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
    Pergunte ao FixBot
    Comentar
  2. DigiTech RP70 Input/Output ¼” Ports  Replacement: passo 2, imagem 1 %32 DigiTech RP70 Input/Output ¼” Ports  Replacement: passo 2, imagem 2 %32
    • Remove the back panel to expose the motherboard.
    Pergunte ao FixBot
    Comentar
  3. DigiTech RP70 Input/Output ¼” Ports  Replacement: passo 3, imagem 1 %32
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
    Pergunte ao FixBot
    Comentar
  4. DigiTech RP70 Input/Output ¼” Ports  Replacement: passo 4, imagem 1 %32
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
    Pergunte ao FixBot
    Comentar
  5. DigiTech RP70 Input/Output ¼” Ports  Replacement, Input/Output ¼” Ports: passo 5, imagem 1 %32 DigiTech RP70 Input/Output ¼” Ports  Replacement, Input/Output ¼” Ports: passo 5, imagem 2 %32
    • Desolder the back of the motherboard where the damaged input/output port is located.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 523
