Ir para o conteúdo principal
Dell XPS 14 Fan Replacement
O que você precisa
    1. Dell XPS 14 Fan Replacement, Back Panel: passo 1, imagem 1 %32
      • Position the computer back side up so that the “XPS” logo is facing you.
      • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Dell XPS 14 Fan Replacement: passo 2, imagem 1 %32 Dell XPS 14 Fan Replacement: passo 2, imagem 2 %32 Dell XPS 14 Fan Replacement: passo 2, imagem 3 %32
      • Use an opening tool to pry up the metal plate.
      • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Dell XPS 14 Fan Replacement: passo 3, imagem 1 %32 Dell XPS 14 Fan Replacement: passo 3, imagem 2 %32
      • Use an opening tool to pop out the back panel.
      • Once unhinged, the panel will open away from you.
      • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
      Pergunte ao FixBot
      Comentar
    4. Dell XPS 14 Fan Replacement: passo 4, imagem 1 %32 Dell XPS 14 Fan Replacement: passo 4, imagem 2 %32 Dell XPS 14 Fan Replacement: passo 4, imagem 3 %32
      • Flip over the back panel so that the interior of the panel is facing up.
      • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
      • Remove the black plastic cover that holds the disk in place.
      • Remove the back panel.
      • The GCE disk should still be connected to the computer via a purple ribbon cable.
      Pergunte ao FixBot
      Comentar
    1. Dell XPS 14 Fan Replacement, Speaker: passo 5, imagem 1 %32 Dell XPS 14 Fan Replacement, Speaker: passo 5, imagem 2 %32
      • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Dell XPS 14 Fan Replacement: passo 6, imagem 1 %32 Dell XPS 14 Fan Replacement: passo 6, imagem 2 %32
      • Remove the speaker from its original location so the wire connector is visible.
      • Unplug the red and white cable plug by pulling out the white end tag.
      • The speaker is now fully removed.
      Pergunte ao FixBot
      Comentar
    1. Dell XPS 14 Fan Replacement, Battery: passo 7, imagem 1 %32
      • Make sure to ground yourself before removing the battery.
      • Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
      • Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Dell XPS 14 Fan Replacement: passo 8, imagem 1 %32 Dell XPS 14 Fan Replacement: passo 8, imagem 2 %32 Dell XPS 14 Fan Replacement: passo 8, imagem 3 %32
      • Detach the battery connector from the motherboard using two thumbs to pop it out.
      • Remove the battery from the laptop.
      Pergunte ao FixBot
      Comentar
    1. Dell XPS 14 Fan Replacement, Fan: passo 9, imagem 1 %32
      • Remove the two 2 mm screws from the fan using a Phillips #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Dell XPS 14 Fan Replacement: passo 10, imagem 1 %32 Dell XPS 14 Fan Replacement: passo 10, imagem 2 %32
      • Use two thumbs to pop out the plug that connects the fan to the laptop.
      • Remove the fan from the laptop.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
UMass Dartmouth, Team 1-3, Botvin Spring 2022 Membro de UMass Dartmouth, Team 1-3, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G3
3 Membros
Autoria de 40 guias
1Comentário do guia
Thanks for sharing! One question: Isn't it sufficient to just remove the plug of the battery?
Thomas - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 23
Ao todo: 556
