Ir para o conteúdo principal
Dell XPS 13 L321X Screen Replacement
O que você precisa
  1. Dell XPS 13 L321X Screen Replacement, Screen: passo 1, imagem 1 %32 Dell XPS 13 L321X Screen Replacement, Screen: passo 1, imagem 2 %32
    • Remove ten 3mm screws from the back cover with a "T5" screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Dell XPS 13 L321X Screen Replacement: passo 2, imagem 1 %32
    • Remove the ribbons from both sides with a plastic iFixit opening tool.
    Pergunte ao FixBot
    Comentar
  3. Dell XPS 13 L321X Screen Replacement: passo 3, imagem 1 %32 Dell XPS 13 L321X Screen Replacement: passo 3, imagem 2 %32
    • Remove the black wire that connects the screen to the motherboard by pulling up with a plastic iFixit opening tool.
    Pergunte ao FixBot
    Comentar
  4. Dell XPS 13 L321X Screen Replacement: passo 4, imagem 1 %32 Dell XPS 13 L321X Screen Replacement: passo 4, imagem 2 %32
    • Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and pulling the white ribbon off.
    • Pull aside the ribbon cable.
    Pergunte ao FixBot
    Comentar
  5. Dell XPS 13 L321X Screen Replacement: passo 5, imagem 1 %32 Dell XPS 13 L321X Screen Replacement: passo 5, imagem 2 %32 Dell XPS 13 L321X Screen Replacement: passo 5, imagem 3 %32
    • Disconnect the wire that is connected to the wireless card with a plastic iFixit opening tool by lifting up slowly, then pulling the wires aside.
    Pergunte ao FixBot
    Comentar
  6. Dell XPS 13 L321X Screen Replacement: passo 6, imagem 1 %32
    • Use a PH00 size screwdriver to remove the 8 screws that secure the battery.
    • Six 3mm screws.
    • Two 5mm screws.
    Pergunte ao FixBot
    Comentar
  7. Dell XPS 13 L321X Screen Replacement: passo 7, imagem 1 %32 Dell XPS 13 L321X Screen Replacement: passo 7, imagem 2 %32
    • Insert a plastic iFixit opening tool in between the port and the wires to remove the battery cable.
    Pergunte ao FixBot
    Comentar
  8. Dell XPS 13 L321X Screen Replacement: passo 8, imagem 1 %32 Dell XPS 13 L321X Screen Replacement: passo 8, imagem 2 %32 Dell XPS 13 L321X Screen Replacement: passo 8, imagem 3 %32
    • After removing the battery, start to remove the wireless wire and making it through the other wires connected under the battery.
    Pergunte ao FixBot
    Comentar
  9. Dell XPS 13 L321X Screen Replacement: passo 9, imagem 1 %32 Dell XPS 13 L321X Screen Replacement: passo 9, imagem 2 %32
    • Remove the screws with a PH1 size screwdriver.
    • Each side of the brackets that are holding the screen down are going to have two 3mm screws in each side.
    Pergunte ao FixBot
    Comentar
  10. Dell XPS 13 L321X Screen Replacement: passo 10, imagem 1 %32 Dell XPS 13 L321X Screen Replacement: passo 10, imagem 2 %32 Dell XPS 13 L321X Screen Replacement: passo 10, imagem 3 %32
    • Open the laptop by separating the screen from the actual laptop and take it apart.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Molly Skinner
Membro desde: 02/15/17
270 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S6-G3, Lacy Spring 2017 Membro de USF Tampa, Team S6-G3, Lacy Spring 2017
USFT-LACY-S17S6G3
4 Membros
Autoria de 5 guias
2Comentários do guia
That would be the guide to take off the upper DISPLAY ASSEMBLY, not the screen.
I was expecting you to bring iOpeners and get the actual glass LCD out …
But it’s a good guide.
Xavier Jiang - Responder Compartilhar
Is there a way only the screen can be replaced on Dell XPS 13, not the entire display assembly. From what I have got so far, the entire panel above the keyboard is a single unit
Abhi B - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 34
Ao todo: 4,843
