Ir para o conteúdo principal
Dell XPS 13 9305 Battery Replacement
O que você precisa
  1. Dell XPS 13 9305 Battery Replacement, Remove the back screws: passo 1, imagem 1 %32 Dell XPS 13 9305 Battery Replacement, Remove the back screws: passo 1, imagem 2 %32
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to remove the eight 3.2 mm-long screws.
  2. Dell XPS 13 9305 Battery Replacement, Release the clips: passo 2, imagem 1 %32 Dell XPS 13 9305 Battery Replacement, Release the clips: passo 2, imagem 2 %32
    • At each corner, insert an opening pick between the back cover and the device body.
    • Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
  3. Dell XPS 13 9305 Battery Replacement, Remove the back cover: passo 3, imagem 1 %32 Dell XPS 13 9305 Battery Replacement, Remove the back cover: passo 3, imagem 2 %32 Dell XPS 13 9305 Battery Replacement, Remove the back cover: passo 3, imagem 3 %32
    • The edges of the cover are very sharp. Use caution when handling this panel.
    • Lift the front edge of the cover away from you.
    • Some clips may release during this step. If the cover is stuck, move it side to side to help release additional clips.
    • Remove the back cover from the laptop.
  4. Dell XPS 13 9305 Battery Replacement, Disconnect the battery cable: passo 4, imagem 1 %32 Dell XPS 13 9305 Battery Replacement, Disconnect the battery cable: passo 4, imagem 2 %32 Dell XPS 13 9305 Battery Replacement, Disconnect the battery cable: passo 4, imagem 3 %32
    • Push the battery connector out of its socket using the pointed end of a spudger.
    • Push the small tabs on the side of the connector to avoid damaging the cables.
  5. Dell XPS 13 9305 Battery Replacement, Unfasten the battery: passo 5, imagem 1 %32 Dell XPS 13 9305 Battery Replacement, Unfasten the battery: passo 5, imagem 2 %32
    • Use a Phillips screwdriver to remove the five screws securing the battery:
    • Four 2.4 mm-long screws
    • One 4.4 mm-long screw
  6. Dell XPS 13 9305 Battery Replacement, Remove the battery: passo 6, imagem 1 %32 Dell XPS 13 9305 Battery Replacement, Remove the battery: passo 6, imagem 2 %32 Dell XPS 13 9305 Battery Replacement, Remove the battery: passo 6, imagem 3 %32
    • Lift the battery straight out of its recess and remove it.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
125.004 Reputação
Autoria de 582 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.430 guias
Um comentário
This replacement was extremely simple. I have some experience from years ago when I replaced laptop parts during an internship, but was worried things might have gotten a lot more complicated in the 15+ years since. But it was super easy. This guide + the toolkit made it an absolute breeze. I was actually surprised how easy this was. I'm convinced almost anyone can do this. Thanks for the tutorial!
Bono - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 49
Últimos 30 dias: 197
Duração total: 2,111
