Introdução
Use this guide to replace the battery in your Dell XPS 13 9305 Laptop.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
O que você precisa
Use a Torx T5 screwdriver to remove the eight 3.2 mm-long screws.
At each corner, insert an opening pick between the back cover and the device body.
Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
Lift the front edge of the cover away from you.
Remove the back cover from the laptop.
Push the battery connector out of its socket using the pointed end of a spudger.
Use a Phillips screwdriver to remove the five screws securing the battery:
Four 2.4 mm-long screws
One 4.4 mm-long screw
For optimal performance, calibrate your newly installed battery after completing this guide.
Um comentário
This replacement was extremely simple. I have some experience from years ago when I replaced laptop parts during an internship, but was worried things might have gotten a lot more complicated in the 15+ years since. But it was super easy. This guide + the toolkit made it an absolute breeze. I was actually surprised how easy this was. I'm convinced almost anyone can do this. Thanks for the tutorial!
