Ir para o conteúdo principal
Dell OptiPlex GX260 Case Replacement
  1. Dell OptiPlex GX260 Case Replacement, Case: passo 1, imagem 1 %32 Dell OptiPlex GX260 Case Replacement, Case: passo 1, imagem 2 %32
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
    Pergunte ao FixBot
    Comentar
Conclusão
To close the case, simply press it closed until you hear the tabs click into place.
18 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 4-48, Amido Fall 2010 Membro de Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Membros
Autoria de 27 guias
1Comentário do guia
Thanks, couldn’t for the life of me figure out how to open the silly thing. :)
technojunkie_1999 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 76
Ao todo: 20,142
