Ir para o conteúdo principal
Dell Inspiron 3501 Battery Replacement
O que você precisa
  1. Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: passo 1, imagem 1 %32 Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: passo 1, imagem 2 %32
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips screwdriver to remove the seven screws securing the back cover:
    • Three 5 mm-long screws
    • Four 7.5 mm-long screws
    • Loosen the three captive screws.
  2. Dell Inspiron 3501 Battery Replacement, Unclip the front corners: passo 2, imagem 1 %32 Dell Inspiron 3501 Battery Replacement, Unclip the front corners: passo 2, imagem 2 %32
    • Flip the laptop upright and open the lid so that the keyboard is exposed.
    • Insert an opening pick between the front right corner of the back cover and the chassis.
    • Pry upward to release the retaining clips holding the cover.
    • You'll hear clicks whenever a clip is released.
    • Repeat this procedure for the opposite corner.
  3. Dell Inspiron 3501 Battery Replacement, Unclip the front edge: passo 3, imagem 1 %32 Dell Inspiron 3501 Battery Replacement, Unclip the front edge: passo 3, imagem 2 %32
    • Insert an opening pick between the front edge of the back cover and the chassis, near the trackpad.
    • Pry upward to release the clips along the front edge of the laptop.
  4. Dell Inspiron 3501 Battery Replacement, Remove the back cover: passo 4, imagem 1 %32 Dell Inspiron 3501 Battery Replacement, Remove the back cover: passo 4, imagem 2 %32 Dell Inspiron 3501 Battery Replacement, Remove the back cover: passo 4, imagem 3 %32
    • Close the screen to the laptop and flip it over.
    • Pull the left side of the back cover away from the frame and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
  5. Dell Inspiron 3501 Battery Replacement, Disconnect the battery: passo 5, imagem 1 %32 Dell Inspiron 3501 Battery Replacement, Disconnect the battery: passo 5, imagem 2 %32
    • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
  6. Dell Inspiron 3501 Battery Replacement, Unfasten the battery: passo 6, imagem 1 %32 Dell Inspiron 3501 Battery Replacement, Unfasten the battery: passo 6, imagem 2 %32
    • Use a Phillips screwdriver to remove the three 3.3 mm-long screws securing the battery.
  7. Dell Inspiron 3501 Battery Replacement, Remove the battery: passo 7, imagem 1 %32 Dell Inspiron 3501 Battery Replacement, Remove the battery: passo 7, imagem 2 %32 Dell Inspiron 3501 Battery Replacement, Remove the battery: passo 7, imagem 3 %32
    • Lift the battery straight out of its recess and remove it.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
127.767 Reputação
Autoria de 592 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.895 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 92
Duração total: 1,381
