Ir para o conteúdo principal
Dell Inspiron 15 7579 Battery Replacement
O que você precisa
  1. Dell Inspiron 15 7579 Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Battery Replacement: passo 2, imagem 1 %32 Dell Inspiron 15 7579 Battery Replacement: passo 2, imagem 2 %32
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Battery Replacement, Battery: passo 3, imagem 1 %32 Dell Inspiron 15 7579 Battery Replacement, Battery: passo 3, imagem 2 %32
    • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
  4. Dell Inspiron 15 7579 Battery Replacement: passo 4, imagem 1 %32
    • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
    • Remove the battery from the device.
Conclusão
10 outras pessoas executaram este guia.
Inaki Madrigal
Membro desde: 04/23/18
775 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S24-G9, Maness Spring 2018 Membro de Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
Membros da 4
Autoria de 6 guias
2 comentários
Thanks! Very helpful and to the point!
You ARE TECHNICALLY missing one step however, removing the fabric ribbon from the old battery at the end. Yes, it seems like common sense but…
Anyways, thanks.
Thomas Keats - Responder
Thanks for the help, worked well.
Remember the connector needs to be removed from the old battery and re-installed in the new. I used a small slotted screwdriver.
A. Holness
June 7, 2020
andrew.w.holness - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 41
Duração total: 7,117
