Ir para o conteúdo principal
Dell Inspiron 15 5577 Gaming Battery Replacement
O que você precisa
  1. Dell Inspiron 15 5577 Gaming Battery Replacement, Battery: passo 1, imagem 1 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Unscrew the back cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 15 5577 Gaming Battery Replacement: passo 2, imagem 1 %32
    • Remove the back cover using an opening tool.
  3. Dell Inspiron 15 5577 Gaming Battery Replacement: passo 3, imagem 1 %32 Dell Inspiron 15 5577 Gaming Battery Replacement: passo 3, imagem 2 %32
    • Use a T8 Torx driver to remove the five screws around the battery.
  4. Dell Inspiron 15 5577 Gaming Battery Replacement: passo 4, imagem 1 %32
    • Remove the Battery Cable by gently tugging it perpendicular from the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Battery Replacement: passo 5, imagem 1 %32
    • Pull the battery out of the laptop by prying it away from the laptop. If you're having difficulty removing it, you can also use a plastic opening tool.
Conclusão
Uma outra pessoa concluiu este guia.
[deleted]
Membro desde: 10/31/19
346 Reputação
Autoria de 2 guias
Um comentário
Thank you, you guys rock
Random User - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 60
Ao todo: 5,703
