Introdução
This guide shows how to remove and replace a worn out battery for the Dell Inspiron 13-7352 laptop.
O que você precisa
Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
Use the plastic opening tool to pry up and loosen the back panel.
Remove the back panel.
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 outras pessoas executaram este guia.
3 comentários
Hello,
My Dell Inspiron 13-7352 won't turn on; I was using it when there was power outage and I totally drained the battery and it went off automatically, after the power came back I charged it the whole night but it still totally doesn't turn on. I tried to long-press the power button but nothing happens. I am 99% sure that the reason was using it on battery until the whole charge was gone. Please help!
