Ir para o conteúdo principal
Dell Inspiron 13-5368 Battery Replacement
O que você precisa
  1. Dell Inspiron 13-5368 Battery Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 13-5368 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Battery Replacement: passo 2, imagem 1 %32 Dell Inspiron 13-5368 Battery Replacement: passo 2, imagem 2 %32
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Battery Replacement: passo 3, imagem 1 %32
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Battery Replacement: passo 4, imagem 1 %32
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Battery Replacement: passo 5, imagem 1 %32 Dell Inspiron 13-5368 Battery Replacement: passo 5, imagem 2 %32
    • Remove the battery.
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
14 outras pessoas executaram este guia.
Matt Sugrim
Membro desde: 09/27/17
1.042 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S14-G6, Boczar Fall 2017 Membro de USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
Membros da 4
Autoria de 13 guias
3 comentários
Awesome, very user friendly instructions. Was not looking forward to taking to computer repair store to replace internal battery. Thank you so much for these instructions.
rdcath - Responder
The new battery replacement does not come with a cable to attach to the motherboard. How can I use the cable from the old battery?
BilboBaggins314 - Responder
I have this same question^. Can I reuse the cable from the old battery?
Gloria Kolyabin -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 34
Últimos 30 dias: 154
Duração total: 24,789
