Introdução
This guide shows how to remove and replace the battery pack for the Dell Alien 18 laptop.
O que você precisa
Use a Phillips screwdriver to remove the three screws securing the base cover.
Slide the base cover towards the rear of the computer and lift it off the computer base.
Use a Phillips screwdriver to remove the two screws securing the battery to the computer base.
Disconnect the battery cable from its connector by pulling it straight up from its socket.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Uma outra pessoa concluiu este guia.
