Ir para o conteúdo principal
Dell Alienware 18 Battery Pack Replacement
O que você precisa
  1. Dell Alienware 18 Battery Pack Replacement, Before You Begin: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Dell Alienware 18 Battery Pack Replacement, Remove the base cover screws: passo 2, imagem 1 %32
    • Use a Phillips screwdriver to remove the three screws securing the base cover.
  3. Dell Alienware 18 Battery Pack Replacement, Slide the Cover: passo 3, imagem 1 %32
    • Slide the base cover towards the rear of the computer and lift it off the computer base.
  4. Dell Alienware 18 Battery Pack Replacement, Prelude: passo 4, imagem 1 %32
  5. Dell Alienware 18 Battery Pack Replacement, Remove the battery screws: passo 5, imagem 1 %32
    • Use a Phillips screwdriver to remove the two screws securing the battery to the computer base.
  6. Dell Alienware 18 Battery Pack Replacement, Disconnect the battery cable: passo 6, imagem 1 %32
    • Disconnect the battery cable from its connector by pulling it straight up from its socket.
  7. Dell Alienware 18 Battery Pack Replacement, Remove the battery: passo 7, imagem 1 %32
    • Remove the battery from its recess.
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
Uma outra pessoa concluiu este guia.
darrius
Membro desde: 03/26/18
5.213 Reputação
Autoria de 30 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
Um comentário
This is the wrong computer being displayed here.
Tru-B -DaT - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 1,200
