Ir para o conteúdo principal
Damaged Wire Replacement
O que você precisa
    1. Damaged Wire Replacement, Trim Away Damaged Portion: passo 1, imagem 1 %32 Damaged Wire Replacement, Trim Away Damaged Portion: passo 1, imagem 2 %32 Damaged Wire Replacement, Trim Away Damaged Portion: passo 1, imagem 3 %32
      • Using pliers, trim away the damaged portion of the wire.
      • You should be left with two neatly trimmed wire ends.
      Pergunte ao FixBot
      Comentar
    2. Damaged Wire Replacement, Cut Replacement Wire: passo 2, imagem 1 %32 Damaged Wire Replacement, Cut Replacement Wire: passo 2, imagem 2 %32
      • Cut a new replacement section of wire. This section will be connected between the two wires in the previous step.
      • The length of this new section varies for each repair. You decide what length is most suitable for your fix.
      Pergunte ao FixBot
      Comentar
    3. Damaged Wire Replacement, Strip Wire Ends: passo 3, imagem 1 %32 Damaged Wire Replacement, Strip Wire Ends: passo 3, imagem 2 %32 Damaged Wire Replacement, Strip Wire Ends: passo 3, imagem 3 %32
      • Using the wire strippers, strip roughly the first 1-2cm of wire insulation on each end.
      • The result should look as illustrated in the third picture.
      Pergunte ao FixBot
      Comentar
    4. Damaged Wire Replacement, Slide Heat Shrink On To Wire: passo 4, imagem 1 %32 Damaged Wire Replacement, Slide Heat Shrink On To Wire: passo 4, imagem 2 %32
      • Slide a piece heat shrink tubing onto both ends of the main wires.
      Pergunte ao FixBot
      Comentar
    5. Damaged Wire Replacement, Fray Wire Ends: passo 5, imagem 1 %32 Damaged Wire Replacement, Fray Wire Ends: passo 5, imagem 2 %32
      • Using pliers, slightly fray the ends of each of the exposed wires.
      • Small exposed wires are extremely sharp and can cause injury to bare hands.
      Pergunte ao FixBot
      Comentar
    6. Damaged Wire Replacement, Crimp Wire Ends Together: passo 6, imagem 1 %32 Damaged Wire Replacement, Crimp Wire Ends Together: passo 6, imagem 2 %32
      • Using the pliers, connect each of the wire segments by intertwining and twisting them together.
      • Once done, lightly crimp each of the connections with the pliers.
      Pergunte ao FixBot
      Comentar
    7. Damaged Wire Replacement, Use Heatgun: passo 7, imagem 1 %32 Damaged Wire Replacement, Use Heatgun: passo 7, imagem 2 %32
      • Slide the heat shrink tubing over the exposed wires.
      • Using the heat gun, slowly go back and forth over the shrink wrap, allowing for even heat distribution and the wrap to close.
      • Depending on the heat gun setting, shrink wraps should take anywhere from 10-25 seconds to fully constrict around the wire.
      • Heat guns take little time to heat up and much longer to cool down. Use caution when setting this tool down and make sure it's cool when picking it up after use.
      Pergunte ao FixBot
      Comentar
    8. Damaged Wire Replacement, Repair Is Complete!: passo 8, imagem 1 %32
      • Throughly check for any exposed wires and the heat shrink tubing is tight around the wire.
      Pergunte ao FixBot
      Comentar
Conclusão
After inspecting the replaced section, the repair is complete and the wire is ready to be tested.
46 outras pessoas executaram este guia.
Nicholas Pierson
Membro desde: 01/30/20
1.559 Reputação
Autoria de 1 guia
6Comentários do guia
Muito ruim!!
Ivanilson - Responder Compartilhar
Heat shrink is for strain relief - not joining cables. I'd suggest solder sleeves. You'd need a heat gun either way, but this method solders the connection and provides an environmental shield on both ends.
Josh Bowen - Responder Compartilhar
The wires really should be soldered together before putting the heat shrink over the connection. A connection made with this guide could rather easily be broken with a slight pull on the cable. In the worst case, it could cause an electric shock to the user.
HoPo-_ - Responder Compartilhar
Bonjour,
Vous pouvez aussi souder les deux câbles ensemble avant de mettre la gaine thermo en utilisant des connecteurs auto-soudeur que vous pouvez retrouver en cliquant ici.
Merci
Kevin - Responder Compartilhar
何必多間中間那一段 只需要將毀損的部位修平 再將兩頭末端連接即可 多那段有點多餘
Chiu_Chieh - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 53
Últimos 7 dias: 309
Últimos 30 dias: 1,387
Ao todo: 78,313
