Ir para o conteúdo principal
DROCON Ninja Propeller Replacement
  1. DROCON Ninja Propeller Replacement, Battery: passo 1, imagem 1 %32 DROCON Ninja Propeller Replacement, Battery: passo 1, imagem 2 %32 DROCON Ninja Propeller Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
    Pergunte ao FixBot
    Comentar
  2. DROCON Ninja Propeller Replacement, Propeller: passo 2, imagem 1 %32 DROCON Ninja Propeller Replacement, Propeller: passo 2, imagem 2 %32
    • Firmly grasp the blade guard from the bottom of the drone
    • Pull the blade guard straight down away from motor.
    Pergunte ao FixBot
    Comentar
  3. DROCON Ninja Propeller Replacement: passo 3, imagem 1 %32 DROCON Ninja Propeller Replacement: passo 3, imagem 2 %32 DROCON Ninja Propeller Replacement: passo 3, imagem 3 %32
    • Take note of the letter printed on the bottom of the propeller. Make sure the replacement propeller has the same letter.
    • Grasp the center of the propeller that needs to be replaced.
    • Pull the propeller directly up and away from the motor.
    Pergunte ao FixBot
    Comentar
Conclusão
4Comentários do guia
can we buy an extra battery?
Orlay Gutierrez - Responder Compartilhar
can we buy an extra battery for the roconDC-014
hi i have the red & bleu drocon dc-014 & wold like to order the white drocon dc-014 white drone or white body cover
tank you! & happy new year!!!
claude demers - Responder Compartilhar
i both drocon dc-014 blue & red wold like by the white drocon dc-014 or uper casse
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 39
Ao todo: 2,308
